Thoughts about my BOV
Hey I just got that same BOV for testing.
Being open is more like a bypass valve, allowing the turbo to free spin while cruising. I bet the turbo is spinning a little faster as well with no load.
Normally bov are closed while driving and only lift when vacuum is on one side of the piston and boost is on the other side.
I think you will be fine. The blow off you got has a much small hole then a Tial or others do.
High on diesel fumes
I don't think there is ever a time when air comes IN through the BOV, but I did put a small filter on the BOV awhile back, just in case.
Ya, most of them are, it depends on how stiff the spring is. If properly setup, the spring should just be set tight enough to hold it shut at idle, but then when you let off the throttle while boosting, the boost pressure and higher vac you pull when in decel should fully open the valve until the pressure is fully release.
I do get into boost a lot, or right on the verge to where I can hear a lot of air escaping through the BOV. I don't really want to mess with the TC right now...I'd like to figure out this part before I go and try to put a bandaid on it.
Yeah I really like the performance of this unit, I just want to figure out if there's a tradeoff.
Kinda strange, but when we went riding that night in coltons truck, mine does the same except i got the butt mount.. BOV is in the front, but cant hear it yet cause its prolly got a 25# spring..
I forgot to tell yall, i dont have to be in boost to get Compressor Surge..
a standard BOV's spring only needs enough pressure to keep the valve closed at engine vaccum while deaccelarting. Anything more is just a waste and will keep the unit closed to long, in my opinion.
The instructions for the synapse does mention an air filter on the discharge is not plumbing back in, but I'm not planning on running one.
we just installed one of the synapse blowoff valves on my friends gti. your suppose to recirculate it, if u dont put a filter on the end, or get the "anti-stall" insert. its been workin great for him, no compressor surge and it doesnt leak. does its job
