Thinking about boosting lq9.
Old Feb 8, 2012 | 05:49 PM
youngbuck's Avatar
ok thanks. could I use the springs an retainers from the 862s on the 317s? the valves won't work will they? will I be ok on stock compression safety wise?
Old Feb 8, 2012 | 06:56 PM
02'Z71ONDUBZ''s Avatar
Yes, the springs and retainers will work fine on the 317's. A machine shop could fit the valves for you, but I wouldn't mess with it. Have them checked out at a machine shop before you put them on though if you haven't already. You will be good to go compression wise with the 317's, and will be able to run more than 7lbs if you want.
Old Feb 17, 2012 | 11:26 PM
Jablowme's Avatar
Banned
Originally Posted by youngbuck
specs on the 862s are in the first post , I plan on getting thicker head gaskets to lower my compression ratio to a safe level on the 862s, as long as they will be safe an perform better then the 317s. I want it to last so if the 862s will be to risky I will go with with the 317s thoughts? I'm only planning on running 7lbs.
using a thicker gasket will only increase your chance of detination as the piston to head quench area becomes to big with a flat top piston
Old Feb 17, 2012 | 11:35 PM
sik-rod-dog's Avatar
60 lbs inj walbaro intank fule pump and a good tuner u should be able 10lbs no problem that is what i had running on mine for three years
With my old set up
CammedZ71
Aug 30, 2015 04:17 AM
fastjweb
Aug 15, 2015 10:47 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Blackrat48
Jul 12, 2015 07:28 PM
