Thinking about boosting lq9.
Yes, the springs and retainers will work fine on the 317's. A machine shop could fit the valves for you, but I wouldn't mess with it. Have them checked out at a machine shop before you put them on though if you haven't already. You will be good to go compression wise with the 317's, and will be able to run more than 7lbs if you want.
specs on the 862s are in the first post , I plan on getting thicker head gaskets to lower my compression ratio to a safe level on the 862s, as long as they will be safe an perform better then the 317s. I want it to last so if the 862s will be to risky I will go with with the 317s thoughts? I'm only planning on running 7lbs.
60 lbs inj walbaro intank fule pump and a good tuner u should be able 10lbs no problem that is what i had running on mine for three years
With my old set up
With my old set up
05GMC4.8
Aug 7, 2015 09:55 PM
Blackrat48
Jul 12, 2015 07:28 PM
