Tell me about this turbo.
Old Oct 22, 2012 | 02:47 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default Tell me about this turbo.
http://toledo.craigslist.org/pts/3313134965.html
It is worth close to $525? If you don't know I plan to take my 5.3 Tahoe to 8-12 psi would this be a good turbo?
Also look at his claim 660 hp on a mustang at 22psi.!?!? I know it is a shitty *** ford but at 22 psi you should make atleat 800-1000 hp I am thinking on almost any engine?
Old Oct 22, 2012 | 03:20 PM
nonnieselman's Avatar
they are about that much new..
and no fords take alot of boost to make good power.
Id go ahead and skip that one.. get a borg warner
you would be amazed at the power difference between a decent sized BW compared to that one.
Old Oct 22, 2012 | 03:24 PM
custm2500's Avatar
Ph.D. in HUBRIS
Sounds good. Kinda figured. On ebay they seem to be $800 but no reason to save $300 on a questionable turbo.
Old Oct 22, 2012 | 03:25 PM
kbracing96's Avatar
That's not a bad price for a MP T76, but they don't sell them anymore in the US and you can't get parts for them. It will make what he is claiming, I was about that with one on my LS1 in my truck at one point.
Old Oct 22, 2012 | 03:46 PM
Ferocity02's Avatar
They are $800-$900 new. But as mentioned, Master Power no longer exists. They are identical to the Magnum turbos in specs I believe, but the parts are not interchangeable.
Old Oct 22, 2012 | 03:51 PM
fixed...
I was thinking of the cheap ON3 turbos
Old Oct 22, 2012 | 04:00 PM
Johnmaster's Avatar
MASS seller approved
Boost psi doesnt take into account the exh pressure it takes to create it. More boost isn't always more power, the lowest psi it takes to make your power goal will be the most efficient. My next build will either be twins if i can package them or a larger turbine dia and a/r.
Zizzle
Oct 19, 2017 08:44 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
GMCtrk
Oct 20, 2015 06:17 AM
turbo6c3
Oct 5, 2015 06:11 PM
spooneralmighty
Sep 11, 2015 02:28 PM
