Tearing belts -help!!!
Old Mar 22, 2010 | 06:18 PM
terravast4's Avatar
Originally Posted by EVILGMC
upgrade to the HD belt...jsut add HD to the end of your part number.
also...the maggie HD tensioner is a good call.
are you throwing A/C belts, too?
what is the difference between the HD belt and stocker ?
Old Mar 22, 2010 | 09:00 PM
one fast ss's Avatar
I'd contact Joe at LeftCoast32 I have a 8 rib setup from him and it works amazing. He is very knowledgeable about these sort of things and Im sure he can set you in the right direction. I personally would get the HD tensioner, i broke the maggie one so I went to the HD one instead and its been good so far. get the gates HD green belt that supposedly doesn't stretch so it should be good. If you ever have a problem with your AC belt just get one that is 1inch shorter and you'll be set.
Good-luck
Old Mar 23, 2010 | 06:28 AM
dhpro's Avatar
Good-luck
Thnx...already working with Joe. My 8 rib is from him as well...Here are a few pix. R/
Old Mar 25, 2010 | 04:57 PM
supersub's Avatar
lining up the tensioner pulley is the crutial step for geting the belts to survive, and tightning the belt will only cause other problems. Once you get it all lined up, get rid of the idlers and you will also get rid of the "silverback" belt coating as well.
a/c delco and gates make OEM type steel idlers in 76mm and 90 mm dia.
Old Mar 26, 2010 | 06:51 AM
dhpro's Avatar
Thnx Ray...worjking with Joe @ Leftcoast on it. Prob is the lines up everywhere except the idlers...if u look close the pass side rides the inside shoulder, drvs side opposite. I'm gonna try some washer/spacers to line it all up prop and shorten up the belt and see what gives...I'll post it when done. R/
Old Mar 28, 2010 | 03:01 PM
dhpro's Avatar
Well...cleaned up the idlers and centered the belt, but shorter 110.4 belt (v the 112.2) was a solid 1" too short! Working with Joe to see what other options I have other than playing around with diff pulley sizes to squeeze that shorter belt on!
Gadgetized
Oct 22, 2015 09:06 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
trxmxzx
Sep 29, 2015 07:42 AM
murderedSS
Sep 27, 2015 10:16 PM
hackrst
Sep 2, 2015 05:27 PM
