In-Tank or In-Line fuel pump?
Old Jan 31, 2006 | 07:16 AM
Whippled 496's Avatar
Default In-Tank or In-Line fuel pump?
I am going to put this in this section as it directly relates to my S/C application. If this is not right, please move it. Thanks.
I would rather drop the tank and install a replacement pump than the in-line, but only if I can install it without effecting my gauges or making major modifications to the bucket and stuff. If anyone has a part # for a high flow (volume) in-tank kit that will work please let me know.
If i can not go with the In tank setup, then i will have to go with the in-line pump. Im just not sure of the correct way of installing this. I s there a piggyback harness that will connect this up? Does it have a cut off/turn on switch that needs to be installed? Is there a complete kit that is sold for my truck?
Thanks
Jimmie
Old Jan 31, 2006 | 07:24 AM
dewmanshu's Avatar
Moderately Differentiated
Have you contacted racetronix yet? http://racetronix.com/ They are way more knowledgable at matching or knowing if your setup is even matchable with an in tank unit.
Old Jan 31, 2006 | 09:11 AM
02BlueStepside's Avatar
Check out this thread, lots of good info. I am running the same pump and haven't had any problems.
https://www.performancetrucks.net/fo...d.php?t=344727
Old Jan 31, 2006 | 04:01 PM
TIM Z's Avatar
11 sec. Truck Mod
i bought my in tank pump kit from magnuson ,its a walbro unit. part of thier radix kit, 120$ comes with what you need, you can go to thier website and download instructions.
Old Feb 1, 2006 | 10:09 AM
Mort's Avatar
Cool
I would tend to leave the in-tank pump alone working as per factory specs and put an in-line pump on your frame rail plumbed in before your fuel filter using fuel line hose. That is what I did and it is working fine. I actually put mine after the fuel filter by cutting a piece out of the factory steel fuel line. Before the filter would have been a better idea. Racetronix sells a harness which I used and it is a very nice piece and I highly recommend it.
Old Feb 1, 2006 | 10:17 AM
WaitinToDrag's Avatar
I took out the Radix Inline pump and dropped a in tank walbro 255/h. havent run out of fuel yet
Old Feb 1, 2006 | 10:44 AM
K, thanks, thats 2 votes for the Racetronix. I will give them a call and get some #'s.
Waitintodrag:
Do you have a model#, place of purchase, and price on your intank pump? Does your gas guage still work 100%? Did you have to modify anything to fit?
Old Feb 1, 2006 | 11:04 AM
Futral MotorSports dropped the pump in the tank while they were building my motor. I think the pump was like 150$? Gas guage is still 100% accurate and no modification was needed.
I believe this is the part #....F20000169 [high pressure 255]
i just looked this site up....http://www.autoperformanceengineering.com/
ss4chad
Aug 15, 2015 02:25 AM
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
