Talk about prochargers
Old Jul 20, 2017 | 07:53 AM
  #281
XBlackXCheavyX's Avatar
Originally Posted by Blown06
If you wanted to stay in the 700 rwhp range, I'd tell you to do the D1sc/x all day long as belt reliability can be bullet proof with that set up fairly easy if don't properly.
Obviously, the F-series blowers are going to require a little different approach to make sure you have reliability with the belts and stuff but it can still be done. It'll just cost a little more money. The upside to the F-series is better efficiency at higher boost levels, which can help manage IAT's a little better, also they will allow much further room to grow (even though the P, D and F1/F2 blowers can all use the same bracketry with the exception of the F1x-12).
Boost is addictive, but you have to be careful not to fall into the trap of you project evolving into an unfriendly race truck. That can happen easy as boost addiction is real.
Not sure what kind of vehicle you are looking at doing this with or all of the creature comforts that you would like mandatory so I can't offer much more than that.
If you need to get a plan together, let me know and I may be able to point you in the right direction.
Setup will be in a rcsb 2wd Silverado, it will be direct drive for sure mainly used on the street ( not a dd) may see a track from time to time, I want to be able to go out and beat on it and it still be reliable and still be drivable. 900hp is as far as I would ever take it if I decided to turn it up. I don't want it to be a full blown race truck lol just a fun weekend warrior .also on pump gas and meth no e85.
Old Jul 20, 2017 | 01:31 PM
  #282
Nwfjarhead's Avatar
Is it possible to moderate the boost on a procharger setup using a wastegate between the intercooler and throttle body? My thought was rather than constantly changing pullies and belts just set them up to provide what your setup can handle than use the wg and a controller to dial it back or ramp it in as needed.
Old Jul 20, 2017 | 02:24 PM
  #283
Atomic's Avatar
I have a gauge for that
Yes, but in practice thats a bad idea, be a whole lot easier to just do that with your foot with a properly set up tune. More foot = more power.
Old Jul 20, 2017 | 02:34 PM
  #284
Nwfjarhead's Avatar
Why is it a bad idea?
Old Jul 20, 2017 | 02:38 PM
  #285
Atomic's Avatar
Because you are compressing air that takes power to compress just to waste it out of the intake tube. It wont break anything, but you are literally wasting power.
Old Jul 20, 2017 | 02:47 PM
  #286
Nwfjarhead's Avatar
I understand it takes power to compress the air but how much more does it take? If it takes x HP to make say 10lbs does x just simply double in order to make 20lbs? Would the cost in HP be worth the ability to fine tune a boost curve?
Old Jul 20, 2017 | 03:09 PM
  #287
Atomic's Avatar
Power required is basically HP_drive=Pressure*Flow/Efficiency
Depends on those things. A ballpark, for something like a whipple, 15psi of boost at 1450cfm at 6000 at 72% efficieny is 140hp.
A procharger is driven off the crank, which is controlled by the throttle....so just control the throttle and there ya go!
Old Jul 20, 2017 | 04:15 PM
  #288
MikeGyver's Avatar
It should take a lot less power to blow air out a big enough waste gate compared to compressing air into an engine. A variable speed transmission on the procharger would be a better idea. You could overdrive it at low engine speeds and slow it down at higher rpm to give more linear boost. Or just use it as a speed limiter to limit boost. Just use a CVT from a motorcycle and control it with a cable. Easy peasy!
Old Jul 20, 2017 | 10:24 PM
  #289
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
well i thought id say that my turd runs again so far I'm pretty happy with the setup dropping the truck off this sat to get tuned
Old Jul 22, 2017 | 04:36 AM
  #290
Blown06's Avatar
8 Second Truck Club
Atomic is correct. This is a very bad idea. I did a very thorough discussion on the topic either here, ls1tech or the bullet with full explanation why. I'll try to dig up and post up.
