Taking apart a Maggie
Old Apr 21, 2009 | 08:55 PM
BuiltNotBought's Avatar
Default Taking apart a Maggie
How hard would it be to take a mp112 apart. Im goin to have it powder coated. Is there anything that has to be re adjusted or setup right when put back.
Old Apr 21, 2009 | 09:12 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Why not just mask off everything? I wouldn't crack it open badjuju might jump out!
Old Apr 21, 2009 | 09:20 PM
SuperchargedSS's Avatar
Ben, there are a few posts about powdercoating these things. it was highly recommended not to. I would just mask it off and paint it.
Old Apr 21, 2009 | 09:54 PM
Yah they say not to. Because it keeps heat trapped inside. But they come powdercoated.
Old Apr 21, 2009 | 09:55 PM
I know you have a better answer than that.
Old Apr 21, 2009 | 10:16 PM
leftcoast32's Avatar
FormerVendor
They are powdercoated before they are final machined.
Old Apr 21, 2009 | 11:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
If you powdercoat the rotor housing after it has been machined you run the risk of distorting the precision bore the rotors are in. Do it at your own risk, you are looking at about 1150 bucks to fix it if its screwed up.
Old Apr 21, 2009 | 11:42 PM
So id be better of using high heat paint. Theres no issue with taking the nose and j tube of right.
Old Apr 21, 2009 | 11:43 PM
dewmanshu's Avatar
Moderately Differentiated
and that's just the housing and rotor pack...usually the way you figure out it didn't work out is throwing a bunch of junk down the intake track. $$$$$$$
Old Apr 21, 2009 | 11:47 PM
BlownChevy's Avatar
blownerator
25 Year Member
You can, you should purchase some oil, molyguard, and loctite 510 for the nose. Paint it at your own risk......9 times out of 10 we get the blowers back and the 10.00 can of paint costs 500 bucks.
yeah, something close to that!
