Taking apart a Maggie
Old Apr 22, 2009 | 09:14 PM
  #21
BuiltNotBought's Avatar
The nose and the j tube on mine was sealed with some kinda sealant. It was a clearish bright red and very gooie. Then theres the very bottom of the maggie the part youll need to remove to get to the internal H/E. It was sealed by a rubber gasket that sat in its own groove and every bolt hole has it own rubber gasket they also had there own groove. Be careful when you pull the bottom apart the gasket for the bolt holes like to stick to the upper manifold.
Old Apr 22, 2009 | 09:15 PM
  #22
SuperchargedSS's Avatar
post some pics Ben
Old Apr 22, 2009 | 09:16 PM
  #23
Originally Posted by SuperchargedSS
post some pics Ben
Ok ill go snap a couple pics real quick. BRB
Old Apr 22, 2009 | 09:27 PM
  #24
Mangled03gmc's Avatar
Baltimore Whore
I wouldn't powder coat it with it together.. It has oil and such in there and and from the heat needed to cure it might cause problems with leaking oil out during the cure process.. As far as taking it apart thats up to you. I would sand or just scuff the surface up good, tape off the rest and pain it with some good quality paint...
Old Apr 22, 2009 | 09:34 PM
  #25
KySilverado's Avatar
Red stuff is Loctite 510.
Old Apr 22, 2009 | 09:38 PM
  #26
trever1t's Avatar
2nd fastest 5.3 ECSB
Yes, pics please for those of us that want to see!!
Old Apr 22, 2009 | 09:40 PM
  #27
Thats what I did degreased it scuffed it then re cleaned it. But I took it apart and painted it. Im using VHT flame proof 2000deg primer. black, and clear.
PICS UPLOADING
  #28
i know its kinda late, but Grip totally dissected the MP122 that's on my truck now. There are alot of pics on his build thread of when he reassembled it and the tediousness involved.
Old Apr 22, 2009 | 09:43 PM
  #29
I want to see one with several miles on it. I've got pictures of new ones and then of course Grippy probably had a 100 miles on his and cleaned it before taking pictures.
Old Apr 22, 2009 | 09:47 PM
  #30
i think he had ZERO miles on it when he disassembled it.
