t-74 on stock transmission
Old Dec 30, 2007 | 08:14 AM
HorsePower Hunter's Avatar
Originally Posted by dan96z71
Cool, it is always something isn't it. I can't imagine an install going with NO problems. I would expect to get hit by lightning or something. Definitely get some pics of the build.
AMEN!!!!!!!!!
Old Dec 30, 2007 | 08:46 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by HorsePower Hunter
Tranny was built for an AWD with a T-case but now I'm trying to put it in a 4x4 and shafts are different. I thought being that motors were both 6.0s the trans would work and the fact mine was an 80 already, but I got ahead of myself as usual. So, basically what he said^^^^^
I have an extra small spline T case input hub. Came out of my 03 1/2 ton. I swaped it out for the 31 spline hub. If you need one let me know.
Old Dec 30, 2007 | 11:32 AM
Thanks!! I still have the old T case with smaller spline. With stock trans in for now I think I'll send trans back to FLT to get larger shaft. It should hold up until I get it back. I might just run less boost for now. Orrrr just see how much the stock will hold
Old Dec 30, 2007 | 11:56 AM
TURBHOE's Avatar
Originally Posted by stock48
The 4wd 80E has a different output shaft than the 2wd. The shaft is shorter, and the splines go about 1/2'' farther up the shaft. T case also has a larger input hub. You can also go the custom 27 spline route, but then you have to run the 1/2 ton input hub.
i understand the 2wd and the 4wd tail housings and shafts are different. thats a no brainer. what i didn't relize when i wrote that is that the trans was made custom for a awd t-case which is why it had the smaller spline output. i found that latter last night which is why i said *edit* found the thread, now i understand."
zblee
63
Jun 10, 2023 01:25 PM
5.3Okasai
Mar 9, 2022 01:07 PM
thewrx
Aug 12, 2015 08:28 PM
davis28905
Jul 8, 2015 03:20 AM
zaathur151
Jul 6, 2015 10:57 PM
