T-70 Hp???
Old Nov 3, 2007 | 01:09 PM
05crew's Avatar
Default T-70 Hp???
how much RWHP will a T-70 produce? and does the brand matter, between a master power or gartt. ?
Old Nov 3, 2007 | 01:15 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
a precision pt70 is rated at 820 crank, garrett gr42R-70t is 850 rated, a turbonetics tc70 is rated for 850. The garret is around $1200, the turbnetics is around $1000 for a p-trim (non-bb - 1300ish for bb), I don't know the precision pricing for that model (pt70).
the STS "GT70" runs about $1100 an is rated to 750-800, although I had mine up to ~850 (hit 600 on a mustang AWD dyno at 5300rpm and had to lift because the engine was on stuff on fire). It was definitely over cranked at 14psi with the 408 (98* ambient if memory serves).
(good call Jim )
Old Nov 3, 2007 | 01:22 PM
parish8's Avatar
single digit dreamer
hey erik. put some $$ signs in there if you could.
mp70 is good for 600rwhp on a 5.3. prety sure the precision gts 70's would be good for over 700rwhp on the same motor but they cost more than twice as much.
Old Nov 3, 2007 | 02:26 PM
RedHot04's Avatar
Are either of these units worth the trouble on a 5.3 ?
Just saw them a few days ago... Thanks.
SPECS:
$260.00
JDM T70 TURBOCHARGER
Stage-3 Turbo t70. 60.5 - Compressor Wheel.
64.5 Shaft & Wheel, 70 A/R Compressor Housing. (12-22PSi).
CNC Machined Flanges 4Bolt Designed fit most After market Manifold.
Designed Usable for internal Gate Application. And/Or Use A T4 & T70 With An Internal Actuator . (4" inlet air flow).
SPECS:
$200.00
JDM GT45 T4 T04B TURBOCHARGER 1.15 AR.
25 to 35 Psi Peak Power Performance Output Capability.(factory warranty).
And/Or Use A T4 With An Internal Actuator
5 bolt pattern flange for Down pipe.
Old Nov 3, 2007 | 02:35 PM
explorer5.0's Avatar
TOTM: November '07
SPECS:
$260.00
SPECS:
$200.00
There have been a few guys that theturboforums that have had good results with these units. It is a toss up as to the quality though. There was a guy here recently who couldnt make his eBay GT45 make more that 4psi, but I never heard if he found a problem or if it was the turbo. That T70 is not actually a T70 though, it is more like a 62-1 if you look at the specs.
Old Nov 3, 2007 | 03:15 PM
Spoolin's Avatar
GFYS and STFU
One of them has a HUGE A/R housing for a 5.3L
Old Nov 6, 2007 | 10:48 AM
andrewb70's Avatar
If anyone wants to reproduce Parish8's combo on a 5.3L here is what you need:
https://ls1tech.com/forums/showthrea...t=#post8073299
Sorry for the shameless plug....
Andrew
Old Nov 6, 2007 | 03:23 PM
DrTurbo's Avatar
LS1TECH Sponsor
That is a 60mm turbo. Way to small to make any real power, plus the ebay turbos are good for only being paper weights. The units are not balanced, they use standard shaft threading and the wheels are not even HIP'ed....etc..etc.
For the money the Pt70 or the TC70 are the best. The TC70 does have the 1 year no questions asked warranty which is very nice.
SPECS:
$260.00
SPECS:
$200.00
Half-bred
Sep 7, 2010 09:13 PM
kbracing96
Aug 13, 2007 09:58 AM
Black02Z71
Aug 7, 2007 12:47 PM
Black02Z71
Jul 27, 2007 11:30 AM
