Swapped S366 standard for S369sxe What to expect
Old May 16, 2017 | 06:15 PM
  #21
GMCtrk's Avatar
Sorry, i don't buy that flowing as much as a 475.
The turbines are different as stated.
Old May 16, 2017 | 07:31 PM
  #22
94heritage's Avatar
You can see on the 66 where it looks like they have taken a grinder to the edges of the turbine. Thats what I meant by clipped. If you see a 69mm wheel turbo that doesnt have the speed sensor port then it is not the sxe. Also it shouldnt have a turbine housing with it unless you purchased it that way.
Old May 16, 2017 | 07:34 PM
  #23
fastjweb's Avatar
Ordered it with the 1.00 . Thanks for the clarification on turbine wheel, I do see what you mean.
Old May 16, 2017 | 11:14 PM
  #24
mdwatts11's Avatar
Good choice of turbo! I don't think you'll have any issues spooling it. I'm curious to see what your results are.
Old May 17, 2017 | 10:28 AM
  #25
kbracing96's Avatar
I'm curious to see what it does too. I've got a 366 on my c10 and a sxe396 and one of Jose's sxe371 to play with too.
Old May 17, 2017 | 01:39 PM
  #26
I think the big issue with larger displacement engines like these V8s is the shape of the compressor housing. There is a thread on LS1tech about back plate to housing clearance or something.
Attached Thumbnails Swapped S366 standard for S369sxe What to expect-366.jpg   Swapped S366 standard for S369sxe What to expect-369.jpg
Old May 18, 2017 | 02:15 PM
  #27
milesp07's Avatar
You ever make it to the dyno with the s366?
Old May 18, 2017 | 03:35 PM
  #28
lycominghunter's Avatar
No, he never dyno'd the s366. We've been trying to get to the dyno with our trucks, but time is limited and street tunes are life!
Old May 18, 2017 | 04:10 PM
  #29
Vortec350ss's Avatar
Theoretically, if you have a larger/more effient waste gate, couldnt you get away with a more restrictive turbine?
Farmer logic tells me the fin design of the sxe turbine needs a smaller volume of air to spin it to a similar RPM. Therefore allowing for greater use of the wastegate, but not necessarily hurting flow.
Old May 18, 2017 | 05:49 PM
  #30
fastjweb's Avatar
No dyno, enough power for 4200lbs to trap 124.
