Swapped S366 standard for S369sxe What to expect
#31
Thats pretty damn solid. I'm finishing up my S369 Turbo Kit for my RCSB with a 4.8 w/ the same cam you have as well as a 4l80e. I cant wait. Should have it going in the next month or so. The only weak link now will be street tires
#34
Not yet...should be tuned up in the next few days. I think the main difference is that the truck is going to pull to red line / shift point....not fall off and stop making power after ~6000rpm. I'm interested to see the results as well!
#36
I took it one time after turbo swap, On 16lbs and 1.65 60ft, it went 11.1 at 123. DA was 2000ft+ higher then my last best though. and I was seeing 2lbs less boost. Read next thread in this section, I made some other changes thinking I had a bottle neck in the system. New times coming.....
