Swapped S366 standard for S369sxe What to expect
Old May 16, 2017 | 03:18 PM
fastjweb's Avatar
6800 shift point.
Old May 16, 2017 | 03:20 PM
fastjweb's Avatar
Do they make a 369 thats not an SXE?
Asking for a friend...
From what I found there is a s369 with no speed port, etc. Also many different flow rates, I saw 95lbs, 98lbs, 100+, and this one 105.
Old May 16, 2017 | 03:21 PM
fastjweb's Avatar
I think if this will spool as quick as the 66, and flows as much as the s475, it should work well. I guess we will find out.
Old May 16, 2017 | 03:23 PM
fastjweb's Avatar
Originally Posted by Choda
can you just swap turbos and run it to see a real comparison difference?
then add another nozzle and up the boost?
I could, but part me of me says what's the fun in that lol.
Old May 16, 2017 | 03:36 PM
fastjweb's Avatar
Originally Posted by 94heritage
Now I have no personal experience with this so I'm totally going just off of what i have read and seen. But you may not see any gain or actually a loss in performance. From what I understand the compressor side actually does flow a good bit more than the standard 66mm version. But the turbine side is the limiting factor. The sxe chargers run an full back turbine that helps with spool up. The standard version has a clipped back turbine and flows more air out. So the sxe turbine is actually a bigger restriction. Im excited to see
the difference though keep us updated.
They both had the same exhaust wheel, both were clipped too
Old May 16, 2017 | 03:41 PM
fastjweb's Avatar
Old May 16, 2017 | 04:11 PM
Vortec350ss's Avatar
Call me crazy... but they look slightly different to me... no?
the 69 looks like the fins protrude more toward the edge at the exducer?
Old May 16, 2017 | 04:15 PM
fastjweb's Avatar
They could be, when originally looked I didn't see much difference, I thought he meant by clipped was that bat edge along side.
Old May 16, 2017 | 04:23 PM
Hell if I know... I aint a turbo guy
Old May 16, 2017 | 04:29 PM
fastjweb's Avatar
That is true, and I just want to go faster lol
