Supercharger & Turbo
Old Nov 23, 2008 | 10:39 AM
TrickTurbo's Avatar
Truck Sponsor
Yes, you can run both. It is not over complex but it is very expensive. You will have to purchase two kits. 1 blower around 5500.00 and one turbo round 5000.00. If you want to build something like this, the main reason to do it is " you want to" There is no performance gains by this set up in my opinion. But we could make it happen if you really want something like this.
Old Nov 23, 2008 | 02:32 PM
dirt track racer 81's Avatar
just get a turbo kit and spray nitrous off the line
Old Nov 23, 2008 | 03:39 PM
daddyzzs's Avatar
The only reason why I'm asking is because a budy I know in stillwater was working on it on his Toyota excab and then I left for school and lost touch. But I had read in a mag. about people running both and they were trying to figure out the advantages and dis. What I would really want is twins like I had on my Dodge diesel That thing had power for days and killed its fare share of trans!
Old Nov 23, 2008 | 03:40 PM
daddyzzs's Avatar
Just didn't know if there was a benifit to running both or not...But A TURBO IS IN THE NEAR FUTURE, Like CHRISTMAS
Old Nov 23, 2008 | 05:48 PM
zippy's Avatar
For the same amount of money you cana build a big cube turbo setup. Keep the compression at around 10:1 and boost to 12 and below. Lots of low end up plenty of hp.
Old Nov 23, 2008 | 07:06 PM
daddyzzs's Avatar
ok well then how reliable would it be to have a 6L block stroked out with a turbo setup and what would I have to do to hook it up?
Would it work with my stock PCM or would I have to get a new one? Sorry always paid for someone to do this for me I'm try'n to do as much as I can this time....
Old Nov 23, 2008 | 08:43 PM
a turbod 408 would be killer as long as its built good.. the place in hennessey could tune your stock pcm just fine
Old Nov 23, 2008 | 09:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Old Dec 1, 2008 | 08:49 AM
daddyzzs's Avatar
anyone have a sugestion on a motor builder in oklahoma or north-north/west Texas? I'm thinking about ditching the 5.3 and going 6L
Old Dec 1, 2008 | 09:29 AM
KySilverado's Avatar
I've toyed with the idea myself. Only reason being is I already have a charger and it's maxed out. Add a butt turbo and run them both in their peak efficiency ranges. In my case it would be a cheaper alternative with a used STS kit then buying the newer larger blowers out.
