Supercharger & Turbo
Yes, you can run both. It is not over complex but it is very expensive. You will have to purchase two kits. 1 blower around 5500.00 and one turbo round 5000.00. If you want to build something like this, the main reason to do it is " you want to" There is no performance gains by this set up in my opinion. But we could make it happen if you really want something like this.
The only reason why I'm asking is because a budy I know in stillwater was working on it on his Toyota excab and then I left for school and lost touch. But I had read in a mag. about people running both and they were trying to figure out the advantages and dis. What I would really want is twins like I had on my Dodge diesel
That thing had power for days and killed its fare share of trans!
ok well then how reliable would it be to have a 6L block stroked out with a turbo setup and what would I have to do to hook it up? Would it work with my stock PCM or would I have to get a new one? Sorry always paid for someone to do this for me I'm try'n to do as much as I can this time....
I've toyed with the idea myself. Only reason being is I already have a charger and it's maxed out. Add a butt turbo and run them both in their peak efficiency ranges. In my case it would be a cheaper alternative with a used STS kit then buying the newer larger blowers out.
