Stumble when cold
Old Sep 15, 2011 | 07:10 PM
ScreaminChevy's Avatar
Default Stumble when cold
Ever since i went to a colder plug, TR6, my truck will stumble when it is cold. Should I go back to the stock heat range? I'm running about 8 psi of boost.
Old Sep 15, 2011 | 07:54 PM
Alpinestar's Avatar
You might need to have some tuning on your idle done. My truck usually stumbles in 90* weather but it died on me a couple of times today (60* outside) because I'm still running a baseline tune. I'm sure that my truck will idle a lot better in any temperature when Justin starts tweaking on the tune.
Old Sep 15, 2011 | 08:08 PM
smokeshow's Avatar
Mod with training wheels
Does it stumble all over the rpm range or if you get on it?
Old Sep 16, 2011 | 09:42 AM
FarmTruc's Avatar
Performance Trucks Sponsor
You probably need some fine tuning, however, if it wasn't doing it with the stock plugs, there'd be no reason you can't run them, just gap them appropriately.
Old Sep 16, 2011 | 01:24 PM
Yeah just when i first get on it it stumbles then it is fine though out the rpms. But maybe I'll put stock plugs back in. Just wasn't sure if it was alright to keep them in.
Old Sep 20, 2011 | 07:07 PM
j_ahlheim's Avatar
mine does the same thing.
Old Sep 20, 2011 | 07:46 PM
FarmTruc's Avatar
sounds contagious
Old Sep 20, 2011 | 08:21 PM
blue0453's Avatar
Originally Posted by FarmTruc
sounds contagious
lol....
Old Sep 21, 2011 | 06:08 PM
j_ahlheim's Avatar
what gap do you recommend? I believe I gapped mine at .035
Old Sep 21, 2011 | 07:50 PM
FarmTruc's Avatar
5-8psi, .030-.035" should be ok.
calsdad
Jun 14, 2023 11:07 PM
Skip Fix
22
Jul 9, 2016 07:08 PM
turbo6c3
Oct 5, 2015 06:11 PM
Closer_2001
Sep 24, 2015 09:15 PM
fortune46x
Sep 16, 2015 08:18 AM
