Sts wastegate spring
Old Nov 3, 2006 | 07:05 AM
slowec's Avatar
Default Sts wastegate spring
All the post I can find on this talk about color . The one spring that was shipped in my used kit is a plain black spring. It measures .052" Can anybody help on this one or will I have to buy a new spring to be sure. Thanks.
Old Nov 3, 2006 | 08:00 AM
You should have the small red spring; 1.875 OD. That will give you 5.8psi. There is no black spring from Tial. How much boost did the seller say he was running?
You may be looking at the wrong thing.
Tialsport
Old Nov 3, 2006 | 08:23 AM
slowec's Avatar
I am looking @ the right spring. I posted the diameter of the metal itself. I will check the measurements when I get home. I think the paint is worn off. Thanks
P.S.edit
The guy I bought it from never got to install it.
Old Nov 3, 2006 | 09:16 AM
kenihemi's Avatar
Far as I know, sts only shipped yellow or red wg springs.
Anything else would have to be special ordered.
The whole spring isn't painted, just a little sprayed on the side.
Old Nov 3, 2006 | 12:03 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Did you take the spring out of the WG? by default it comes installed.
Old Nov 3, 2006 | 12:16 PM
slowec's Avatar
UMM, I will look at it when I get home. Maybe the stock one is still installed. The one I am speaking of was in a plastic bag. Thanks and I'll let yall know what I find.
Old Nov 3, 2006 | 04:41 PM
kenihemi's Avatar
Carefull putting it back together. It's real easy to pinch the rubber diaphram.
Use a vise if you have you have one.
And watch that you don't strip the threads.
Not saying you are lame, just giving you a headsup.
Old Nov 3, 2006 | 07:29 PM
slowec's Avatar
Took the wastegate apart. Sure nuff. Painted red 1and7/8 " spring is in there. There is some residue in there , maybe balled up lubricant or something. Thanks Hemi, I always take any hints I can get. I am master technician, but a turbo newbie Thanks guys !
ps Any idea what the smaller black spring is for??
Old Nov 4, 2006 | 12:21 PM
Mort's Avatar
Cool
I did not get any loose springs with my kit. I think they just put it in there to confuse you. LOL
It was probably just included in error. How big is it aside from the wire size you already posted?
Old Nov 4, 2006 | 01:12 PM
slowec's Avatar
fits aound my index finger bout that long too.
