STS with towing/offroading
Old Jun 17, 2007 | 05:41 PM
MonsterZ28's Avatar
Default STS with towing/offroading
How does it perform towing?
Does it get messed up if you go through mud or water?
Old Jun 17, 2007 | 11:51 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Just don't get the air filter in the water.
As for towing, it works great, make sure the a/f ratio is nice and rich.
Old Jun 18, 2007 | 03:57 AM
viciousknid's Avatar
Where's the Beef?
It would be great if they could design a filter for those that fits between the bed and cab.
I Want a turbo on mine too but the only disadvantage i could think of is that on the STS setup i'd get mud and water in the filter. Easiest solution to me would be to mount the kit as far forward to the bed as you can and bring the filter up thru the bottom of the bed so it will have clean air. And if you put alot of stuff back there just build an air box for it.
should work right?
Old Jun 18, 2007 | 04:11 AM
Where's the Beef?
One other thing I just thought of that you might want to know about that i'm curious about myself.
Will it hurt the turbo to get fully submerged in water if you back a boat off into the lake? With the filter out of water.
Old Jun 18, 2007 | 06:12 AM
slowec's Avatar
I play on wet roads whenever I can. I have a filter sock on my k&n . I have never had a problem. I have seen some lifted trucks with a filter in the bed. For normal driving on a rainy road there is no need to go to that extreme.
Old Jun 18, 2007 | 07:18 AM
WJ MARK's Avatar
Do you already have one or thinking about it? Have you looked into a Front mount setup like Trick performance??
Old Jun 18, 2007 | 04:13 PM
MonsterZ28's Avatar
I thought about trick's turbo but i just spent 500 in headers and an ORY, what kind of power will the radix put out ?
Old Jun 19, 2007 | 06:38 AM
slowec's Avatar
If you have already went LT's, go look for a deal on a radix. 98% of the population needs no more power than one can provide. Turbos are for power obsessed thrill junkies that would stay up all night before a race just to add 17 HP.
Old Jun 19, 2007 | 08:50 AM
Wilde Racing's Avatar
How do I change this text
I lauch my boat all the time with me STS truck, but I NEVER EVER let the turbo touch the water, it is far enough forward that you should beable to launch a boat with-out getting the turbo wet. but if the turbo is under water and the engine dies................. well I don't really know but it wont be good..
Old Jun 19, 2007 | 10:50 AM
WJ MARK's Avatar
I made the same mistake. Sold the headers to a buddy and bought the Turbo.
