STS with towing/offroading
It would be great if they could design a filter for those that fits between the bed and cab.
I Want a turbo on mine too but the only disadvantage i could think of is that on the STS setup i'd get mud and water in the filter. Easiest solution to me would be to mount the kit as far forward to the bed as you can and bring the filter up thru the bottom of the bed so it will have clean air. And if you put alot of stuff back there just build an air box for it.
should work right?
should work right?
One other thing I just thought of that you might want to know about that i'm curious about myself.
Will it hurt the turbo to get fully submerged in water if you back a boat off into the lake? With the filter out of water.
I play on wet roads whenever I can. I have a filter sock on my k&n . I have never had a problem. I have seen some lifted trucks with a filter in the bed. For normal driving on a rainy road there is no need to go to that extreme.
If you have already went LT's, go look for a deal on a radix. 98% of the population needs no more power than one can provide. Turbos are for power obsessed thrill junkies that would stay up all night before a race just to add 17 HP.
How do I change this text
Originally Posted by MonsterZ28
I thought about trick's turbo but i just spent 500 in headers and an ORY, what kind of power will the radix put out ?
I made the same mistake. Sold the headers to a buddy and bought the Turbo.
