STS help...
Old Jan 24, 2009 | 05:25 PM
UBLUZIN03's Avatar
Default STS help...
I need a PCV check valve. Is this something i have to get from STS or can i get it from a Napa, car quest, etc? Is it even needed or can i run without one?
Old Jan 24, 2009 | 08:08 PM
turbomax's Avatar
i would do away with the PVC check valve and just vent the crankcase that's what i did on my kit
Old Jan 26, 2009 | 11:32 AM
UBLUZIN03's Avatar
TTT anyone else?
Old Jan 26, 2009 | 12:17 PM
Wilde Racing's Avatar
How do I change this text
There are two versions, the older version has no hole, the newwer version has a hole. you want the old version.. You should be able to buy them at any parts store...
Old Jan 26, 2009 | 04:29 PM
UBLUZIN03's Avatar
Is there a certain size? What exactly does it do?
Old Jan 26, 2009 | 04:43 PM
Mort's Avatar
I put a one-way check valve in the line to the PCV from the intake manifold. I got it from a local NAPA store. It is very similar to the one STS puts before the turbo center housing in the oil supply line from the engine.
STS should have one if you cannot find one.
It keeps boost pressure out of the crankcase. Without it boost can pressurize the crankcase because the PCV Valve just has a small hole in it and there is no way for it the stop the boost pressure from the intake manifold.
Old Jan 26, 2009 | 05:09 PM
UBLUZIN03's Avatar
Sweet ill check with napa tomorrow.. You wouldn't happen to remember the part #?
Old Jan 26, 2009 | 06:39 PM
Mort's Avatar
No part #. I looked through my file twice but I have no idea what I did with the invoice.
Old Jan 26, 2009 | 07:32 PM
UBLUZIN03's Avatar
Thats cool thanks for looking. Ill bring the instruction to NAPA and see what they can do..Would i be better off just getting it from STS?
Old Jan 26, 2009 | 11:19 PM
2ktransam's Avatar
It shouldn't be hard to find one at napa and it will be a lot cheaper. I put a normal PCV valve on mine with a breather and it helps it releave crank case pressure a lot better. If you tune your truck for speed density it won't see it as a leak.
nabozny21
Oct 17, 2015 07:47 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
noproblems209
Aug 10, 2015 06:57 PM
Deceptarado
Jul 8, 2015 05:24 PM
