STS guys only !!!
Old Jan 27, 2010 | 07:19 AM
slowec's Avatar
Default STS guys only !!!
My FLT level V 4l65 will be ready soon and the time has come to decide on a converter. I put this in the FI section because I need people that KNOW how a stall acts with a sts and a 6.0. I drive the truck everyday so no huge stalls. I want enough to leave the line with some boost, not lag.
side note: Why in the hell are you maggie guys reading this???
Old Jan 27, 2010 | 08:01 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
On my Lq9 with an STS kit using a GT67, I loved my PI stalled at 3000. It was my dd, and had very good street manners. I was also running an FLT L5 65E.
Chuck and Vince can hook you up. Whatever you decide, make sure you ask for a "turbo stator"
Old Jan 27, 2010 | 12:02 PM
speedaddict's Avatar
I'm running a 2600 with my sts and flt level 5. I'd go 3k if and when I do it over
Old Jan 27, 2010 | 12:08 PM
1BADAZZSS's Avatar
yank 3200 in my 80e. Do hydroboost conversion and you can leave the line on whatever psi you want!!
Old Jan 27, 2010 | 03:09 PM
fastlt1's Avatar
12 Second Club
What rpm can you foot brake to and what PSI? Are you leaving off a 2 step?
Old Jan 27, 2010 | 03:52 PM
Casey2323's Avatar
Default stall
It all depends on the turbo,engine,stall,camshaft.... I would not worry about the 2 step till it gets violent... I have had nothing but problems from mine... size matters also....... and will effect how they work... 9.5 - 10.5" you will be fine with a 3200... Then you can footbrake 3600+ 6psi or so ? that would be great
Old Jan 27, 2010 | 04:08 PM
fastlt1's Avatar
12 Second Club
Would footbrake hold more then transbrake?
Old Jan 27, 2010 | 05:02 PM
Casey2323's Avatar
Default sts
No sir... Unless you have hydra boost you will be doing great to see more then 4-5psi.. and i think thats pushing it 2wd... You can transbrake lots more but... you have to change the fluid ALOT
Old Jan 27, 2010 | 06:00 PM
slowec's Avatar
Thanks for the info. I have been under a rock for a year or two. I have not heard of the hydro conversion. I want my truck to pull away from red lights somewhat stockfish as I drive my GMC more than the Z. I would be worried I could not hook more than a couple of pounds of boost.
What do you guys thinks a circle d 3200 278mm would act like behind my combo?
Thanks again for the great info!!! Keep it coming.
Old Jan 28, 2010 | 12:25 PM
WJ MARK's Avatar
i'd say somewhere between a 2600 and 3000 no more.
