STS GT-67 on a 4.8
Old Feb 28, 2008 | 09:09 PM
minimac21234's Avatar
Default STS GT-67 on a 4.8
ok guys....been on the forums for a while now along with some other forums but i never really chime in all that much. im the kind of person that likes doing things and learning on my own. but im stepping into something really fast without knowing what im doing, so im coming to you guys. i just bought a used sts turbo kit that is meant for a 6.0 ex cab and my truck is a 4.8 sbsc. I have some basic knowledge but im asking for help. What else should i get. This is the one im getting.
https://www.performancetrucks.net/fo...d.php?t=408182
now, short of fuel pump, injectors, and a good tune, this should be all set ready to go. i just want some suggestions as far as everything goes, general info about what i may or may not run into for problems as far as installing this. if anyone has anything help me out. i was looking into getting 60# injectors, walbro fuel pump, and a nelson tune before i start installing this, your thoughts?
readyyyyyyyyyyyyyyyyyyyyyyy go!
-Mike
Old Feb 28, 2008 | 09:43 PM
vanillagorilla's Avatar
That 67mm turbo might be a bit big for you depending on how much boost you're wanting to run and how far you want to push it. Regardless though, you should really ditch the .96 A/R exhaust housing and get a .68 ex housing.
Old Feb 28, 2008 | 09:54 PM
quicksilverado's Avatar
Start saving for a tranny upgrade. Some 918 valve springs to prevent valve float. A higher stall tq conv will get rid of some of the lag. Wrapping the y-pipe and exhaust to the turbo will also help with lag.
Old Feb 28, 2008 | 10:48 PM
kbracing96's Avatar
I agree, your going to need a .68 exhaust housing on the turbo and definitely wrap the pipes to the turbo or it's going to have a bit of lag. I ran the MP T70 I had now for a little bit on my STS, before I wrapped the pipe and it was a bit laggyer then I would have liked. How hard are you going to push it? 60lbs injectors are probable more then your gona need unless you really start to push it. I can tell you that with 42's on my front mount now, I am at about 12-13psi and 6200 shifts and am just hitting 100% DC on the injectors. I'm making in the 520-30 rwhp range there, but I have a small cam and a little meth too.
Old Feb 29, 2008 | 04:15 PM
Originally Posted by kbracing96
6200 shifts
Damn. You have more ***** than me.
FWIW, I run Ford Racing 42lb'rs (about 48lb/hr at our rail pressure) and I'm not really taxing them with 10-11psi and meth. They're cheaper than 60's, but you do have to space up your fuel rails 5/8".
Old Feb 29, 2008 | 04:24 PM
8ALTNG's Avatar
I ran that same setup on my 4.8 liter with 60lb injectors. made decent power and ran 11.8 @120
Old Feb 29, 2008 | 11:45 PM
hey 8ALTNG maybe we can meet up and look some **** over when i get my kit then. i live in tewksbury, ma. right next to lowell where i work.
thanks for the info so far guys. let me remind u though, im very illiterate when it comes to forced air and big performance changes like this, explain some things in detail for me if u think of it so i kind of kno what im getting into here. i want to learn this stuff before i just slap a turbo on without doin injectors fuel pump tune cam etc etc. keep it comin!
-Mike
Old Mar 1, 2008 | 09:43 AM
Wilde Racing's Avatar
How do I change this text
I would say just wrap the exhaust first. then buy a smaller housing if the lag is unbearable. I noticed only a slight increase in lag when I went from the 6.0 to the 5.3.
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
nabozny21
Oct 17, 2015 07:47 PM
97_ek
Sep 23, 2015 09:16 PM
vipergtrdj
Sep 11, 2015 05:52 PM
