sts fuel!!! help
i am trying to run my fuel psi. line to my gauge, and the pcv switch valve is in the way of the service port on the fuel rail cross over. were can i move this switch to make it work?
I just did this on my truck. I showed solid 60 PSI until a few pounds of boost, then it dropped to about 56. I'm running a 3 psi spring, hitting about 5 psi max. What did you get?
ZO6Ted
Aug 12, 2015 07:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
should be fine there! thanks for the help.
