STS Front mount pics, Anybody have any????
Old Jan 30, 2006 | 06:45 PM
Wilde Racing's Avatar
How do I change this text
Default STS Front mount pics, Anybody have any????
I really want to get started on my FMIC, but I can't afford a sts fmic, but I want to run the piping the same way (with out e-fans)
So could some-one post some pics of there set-up that shows all the pipeing from the bov to the throttle body. I know it's a tall order, but I'd do it for you. lol
Old Jan 30, 2006 | 07:12 PM
8ALTNG's Avatar
Here is the only one that I have on this comp. I will try to take a few more this weekend when I get home. Hope this helps
Old Jan 30, 2006 | 07:40 PM
TIM Z's Avatar
11 sec. Truck Mod
i pm ed you, hope it helps.
Old Jan 30, 2006 | 09:50 PM
kbracing96's Avatar
https://www.performancetrucks.net/fo...d.php?t=355254
Lot of pics of my set in this thread, let me know if you want any more, of have any question.
Old Jan 30, 2006 | 10:55 PM
TIM Z you got a P.M.
8ALTNG, thanks, If you would I need some showing how STS gets the pipe from the bov to the throtle body. mostly before the cooler.
kbracing96, I've got all those pics saved, You did that FMIC yourself right? It looks great, I'd like to run the piping after the cooler like you did, instead of back to the passanger side. But I'd like a few more shots of the pipeing before it goes to the cooler.
Thanks again!!!
Old Jan 30, 2006 | 11:22 PM
kbracing96's Avatar
Ya, I built it all. Here is a couple more before the cooler. Anything eles?
Old Jan 30, 2006 | 11:40 PM
What is the filter for in the third pic????
Thanks a bunch them are the pics I want. Thanks again!!
Old Jan 31, 2006 | 12:16 AM
kbracing96's Avatar
That's a cheapy Bosch bypass valve off a Volvo I'm using as a blow off (was a buck on ebay). It's open any time there is vacuum, so I put that filter on it so no dirt is sucked in when it is open.
Also, I keeped the pipe size at 2 1/2" all the way to the intercooler to keep air velocity up and minimize volume in the piping and all so, so I would have less pressure drop across the intercooler and then ran 3" from the cooler to the TB.
Old Jan 31, 2006 | 12:20 AM
How close is the hood when shut to the piping, I just looked at mine and thought the hood would hit, but yours don't A?
Old Jan 31, 2006 | 12:23 AM
kbracing96's Avatar
Its really close, and might rub the insalation a tiny bit, but it fits OK.
