STS exhaust
Old Aug 5, 2009 | 10:45 PM
nonnieselman's Avatar
Default STS exhaust
What size exhaust are you guys running after you Turbo? What size Turbo and how much boost?
Right now i have 3" goin to a 20" long magnaflow (12259) and then another couple feet of 3" pipe.
Think this is too restrictive for 10psi? On lower boost (6#) i can see how it doesnt matter as much cause alot of the exhaust is goin out the wastegate. but on higher boost just wondering if a 4" exhaust could free up some power on 10-12psi...
Old Aug 6, 2009 | 12:20 AM
Dont hate but im thinking about goin with this muffler..
http://www.magnaflow.com/02product/d...rtnumber=12594
Run the turbo to one 3" inlet and the wastegate to the other 3" inlet.. and run a 4" tailpipe.
So?
Old Aug 6, 2009 | 08:28 AM
Toomnymods's Avatar
just a quick question.. what size A/R are you using with your 76mm turbo? I have a 67mm turbo (GT4094R) with 2 diffrent size turbine housings one is a 1.19A/R and the other is a .95 A/R
yea that seems like a good idea to me to run 2 3" pipes to the turbo then a single 4" out the back..
Old Aug 6, 2009 | 09:42 AM
BlownChevy's Avatar
blownerator
25 Year Member
I loved the way this sounded on my truck:
Old Aug 6, 2009 | 10:01 AM
Tommy, its a MasterPower 76 with a .68ar exhaust housing. thats all i know
Blownchevy,
i tried something similar to yours a few times. it was still kinda loud. so i went this muffler and its nice and quiet even when towing.
Im thinking bout this 3" DI/4"SO being 28" long it should be super quiet. and i have some 4" pipe to make a tailpipe with.
just be glad to get the wastegate back into the exhaust. even tho the wastegate sounds cool its stupid loud.
Blownchevy, you ever drive that truck? haha the underside just dont look right all clean and stuff.
Old Aug 6, 2009 | 12:21 PM
Spoolin's Avatar
GFYS and STFU
Blownchevy,
Get a cut-out nonnie. With 3" exhaust going through a magnaflow on high boost I would only see 9-10psi. With the cut-out open it would jump to 17psi. I have one sitting on my shelf if you want it.
Old Aug 6, 2009 | 12:43 PM
BlackGMC's Avatar
Resident Retard
Kinda off subject, but what do your pre-turbo pipes look like???
Old Aug 6, 2009 | 09:48 PM
1BADAZZSS's Avatar
Looks like you found the right muffler to go on it. btw who did the welding on your exhaust, stevie wonder?
Old Aug 6, 2009 | 10:52 PM
Casey2323's Avatar
Default sts exhaust ......
I run a 5" MBRP muffler.... started life about 45lbs and 30" long...... its now only about 6"of muffler.. with two turn downs..... 5.25" into the turbo and 5" out... [IMG][/IMG] this pic is muffler less.... but u get the idea.....
flatblack83
Jan 3, 2026 07:10 PM
blown02408
Feb 24, 2016 04:50 AM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
Deceptarado
Jul 8, 2015 05:24 PM
