stock 6.0l power limitation
Old May 16, 2006 | 12:44 AM
cheap69turboss's Avatar
Default stock 6.0l power limitation
i got 01' gm lq4 block with 5k mile on it, putting it in a 69 camaro along with the turbo system, how much power can i safely get out of this forced induction set up, planning doing a twin set up what size of turbo should i use. thank a lot for any susgestion.
Old May 16, 2006 | 04:40 PM
parish8's Avatar
single digit dreamer
with valve springs and some good fuel or meth, over 600rwhp.
there is little point in doing twins if your sticking with a stock 6.0 unless you just want the look of twins. a single t76 works nicely on a 6.0. something a little smaller might be better if you have a stick.
Old May 16, 2006 | 05:10 PM
vanillagorilla's Avatar
You could ask this question over at tech too. There are some guys with this setup in their cars. I assume you'll at least be putting a cam in it right?
Old May 16, 2006 | 09:27 PM
the 6.0l will bolt to either 200r4 or muncie m22(already in the car) so 600hp is my goal, what's cam should i use, and what's the trans that you guy would rather go with, the car will be driven on highway.
Old May 16, 2006 | 09:35 PM
6.0caddy's Avatar
parish8 would you perfer the cmotorsports or the sts kit? stock lq4
Old May 16, 2006 | 09:49 PM
parish8's Avatar
if your looking for max hp you can't beat the cmotorsports set up but i dont think they are selling it. the livernois kit is about the same and you can buy one of those.
Old May 17, 2006 | 12:17 PM
6.0caddy's Avatar
Cause my truck is a daliy driver and heard about water getting suck up with the rear mount kits.
Old May 17, 2006 | 01:29 PM
parish8's Avatar
that is'nt much of an issue unless you drive thru deep water.
i do think the front mount will give you boost sooner and carry the power longer.
Old May 17, 2006 | 02:50 PM
F8L Z71's Avatar
I agree except that sucking up water can happen fairly easy if the rains are hard enough and you are boosting high enough. I did it and crushed a ring gap on my 2nd motor. Still ran the 12.3 on the engine knocking like a SOB. Hahaha
Old May 17, 2006 | 07:02 PM
6.0caddy's Avatar
yeah, thats my only problem with the sts. I live up in the hills and drive in the snow sometimes. I want to keep my motor in whole. Dont want to get a 408 now lol.
