stand alone 2bar to log boost...
Log the voltage it outputs at key up that will equal 100Kpa depending on where you are. With that baseline just see if the voltage goes up or down for boost. If you know what youre max boost and max vacuum levels log the higest and lowest readings and make a chart. You should be able to transfer that info to create your custom PID.
