SS Silverado Turbo ET
Old Mar 6, 2004 | 10:03 PM
  #41
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by BigTex
He really needs to spend a little effort and make up an output shaft for the 4L80E to mate with SS AWD transfer case. I'll buy one and I'm sure I can find a dozen others who would want one. Count XLR8NSS in for one as well.
Yep, that would be nice. I wouldn't even think about modding my current truck anymore if I knew there was a bulletproof trans option(aftermarket or otherwise) for the SS trucks. A 4L80E is what they should've come with in the first place. GM screwed up on that one.
Like I mentioned in the other thread though it would be better to keep the beefier 80e output shaft and modify the input of the transfer case.
Kurt - How about it?
Old Mar 6, 2004 | 10:58 PM
  #42
parish8's Avatar
single digit dreamer
tex you should try and hook yourself up with an autotrack from a 2500, i wouldn't be suprized if that splined part right inside the case was the same for the 2500autotrack and your case.
the 2 cases i have(2500HD and a 1500 auto) look exactly the same on the out side, i am sure some of the internal parts are the same. maybe some research at the dealer would tell you too. only other thing i can think of is geting that input hub machined out to take the 4l80e shaft, can that type of machining be done?
Old Mar 6, 2004 | 11:46 PM
  #43
BigTex's Avatar
Here is some info from the manual transfer case options from GM. Looks like the 60E has a 27 spline Tcase and the 80E has a 32 spline. Does this sound correct?
Old Mar 7, 2004 | 08:58 AM
  #44
Originally Posted by Reckless
Kurt....me thinks I will have to buy an Silverado SS after I get up there and throw some forged stuff in the motor and one of those kits We can dominate the truck classes at the LS1Tech events
What truck classes? Maybe a hundred forum members in Texas area and they can't fill a class.I hope it's better around Motorcity.
Old Mar 7, 2004 | 09:05 AM
  #45
Reckless's Avatar
Still moddin'
Well after W2W starts selling turbo kits, that might just change for the better!
Old Mar 7, 2004 | 09:42 AM
  #46
427's Avatar
427
I'm going to guess I added about 200-300 on the truck. If a stock SS ever comes by I will try and weigh it.
Kurt
5516 pounds, really? How much weight did you add with the turbo parts? I'm suprised its that heavy. I know my 99 Z71 excab with basically the same drivetrain weighed just over 5100 without driver. I can't see my SS weighing that much more (at least I hope not).
Kurt, I think you'll like that Gtech. I like mine. I dont have any current logged runs or any nitrous runs, but here are a couple of NA runs from a few months back:
Old Mar 8, 2004 | 08:12 AM
  #47
2003blue5.7's Avatar
Kurt
Hey Kurt FYI you have some competition out there
http://www.ststurbo.com/
Old Mar 8, 2004 | 08:20 AM
  #48
Reckless's Avatar
Still moddin'
I would not call that competition, unless you are happy with 350rwhp Besides, what kind of truck owner would place the air inlet for their expensive turbo in that location? I guess if you live in SoCal where it never rains or snows, and the roads are always clean, then it would be fine. I doubt the tubo would last very long before needing a rebuild if you drive in any kind if weather. And how does that filter keep the turbo from sucking water when it is really wet outside? Is there some kind of shield that goes under the air cleaner?
Old Mar 8, 2004 | 08:57 AM
  #49
After seeing Kurts set up in person I have to show him that... "BIG" difference between the two
Old Mar 8, 2004 | 11:28 AM
  #50
427's Avatar
427
Pat, I seen that system on a truck at the sema show. It seems interesting, simple install. Not sure how the cat will like being in front of the turbo. The old ford 2300's did it that way. I think our kit will be better for higher hp gains, only time will tell.
Kurt
