spark plugs, and gap for blower
Old Nov 13, 2005 | 04:37 PM
TwoFast's Avatar
Default spark plugs, and gap for blower
I plan on running NGK RT6 plugs gapped at 32 for the sidemount magnacharger (boost: 4-5psi). Is this good for my application, I just want to get some more opinions on the subject. Thanks
Old Nov 13, 2005 | 05:26 PM
BlownChevy's Avatar
blownerator
25 Year Member
We reccomend factory spark-m-plugs gapped to the factory spec......
The NGK would be my second choice.
Old Nov 13, 2005 | 05:39 PM
TwoFast's Avatar
many told me that stock platinum plugs give you false knock or something.... so I should really stick to my stock plugs,, could there be a gain if I got the Rt6's and had allen tune the for the blower or is that possible???
Old Nov 14, 2005 | 11:03 AM
COLDZ71's Avatar
I was planning on using tr6s but a lot of people said that regular ole tr55s would be fine. Anyone else have any more input on this?
Old Nov 14, 2005 | 11:08 AM
Mr. Sandog's Avatar
My truck runs better with TR6's than it did with factory TR5's.
Old Nov 14, 2005 | 01:00 PM
Bill Reid's Avatar
Best plugs to run are TR6's gapped at 0.035... how they come out of the box. Factory plugs and TR55's are too hot for FI apps.
Bill
Old Nov 14, 2005 | 09:55 PM
WydOpen's Avatar
Bill
I'm a big fan of the NGK TR6 plugs. Running them on my 2005 supercharged Hemi Ram and my 2004 supercharged Saleen. Both are gapped at 0.035" and no problems, whatsoever. Saleen is running 12 lbs of boost and the truck is running 8-10 lbs.
Old Nov 14, 2005 | 09:57 PM
TwoFast's Avatar
should I gap mine at .035 with my blower making 5psi, or should it be .032?
Thanks for the help..
Old Nov 14, 2005 | 10:07 PM
WydOpen's Avatar
I would say you'll be safe with a 0.035" gap. I've run pretty much the same gap on my plugs with three different S/C pulley sizes ranging from 4.00" (6 lbs boost) to 3.25" (11-12 lbs boost). I'm currently running a 3.50" pulley and 8-10 lbs boost. I think initially I had them at 0.037".
Others can chime in who have more knowledge of your specific set-up/application, though...
Old Nov 14, 2005 | 10:10 PM
BlownChevy's Avatar
blownerator
25 Year Member
I have no trouble makeing 450 rwhp with the same plugs that they installed at the factory....This is just my experiance though.....
