Sizing a turbo correctly
Old 04-17-2016, 08:21 PM
Truck Sponsor
TrickTurbo's Avatar
Yes s300 with a 71 compressor wheel.
S400 t4 with small wheels is fine.
Starting with s400t4 small wheels, if later in life plans are to go big.
Allow you swap turbos with out swapping anything else.
So when spec'ing a turbo kit. All aspects need to be considered.
Present, and future plans plus budget.
Old 04-18-2016, 05:05 AM
92SS Wagon's Avatar
thats cool im still lost wth
Old 04-18-2016, 10:33 AM
Truck Sponsor
TrickTurbo's Avatar
There are several turbos that fit your power levels. Easy to get lost on choosing a turbo.
S300 will work,
Old 04-18-2016, 04:36 PM
92SS Wagon's Avatar
bump
Old 04-26-2016, 08:38 PM
lxcoupe's Avatar
bump
If you don't know what you're doing (I didn't either), you're better off buying a kit and not spending months obsessing over the fundamentals. You'll learn 75% of what you're confused about by just bolting the kit on... Every other guy on this forum has a kit from either KB or Trick, and for good reason. Summer is upon us, better to spend your time boosting around town vs reinventing the wheel (turbine and compressor in this case).
Old 04-27-2016, 04:48 AM
92SS Wagon's Avatar
Makes sense and I appreciate your thoughts. Wasn't really trying to reinvent anything though just a better understanding. Good points though and I'll look more into the kits.. I've got the funds to begin
Old 04-27-2016, 08:14 AM
Choda's Avatar
FYI - my 70mm magnum turbo from Tricks older stage II spools perfectly on my stock truck and makes 500 wheel at 12 psi.
a little "better" and larger turbo would make more power with less load. Esp with a cam and supporting mods. Keep an eye on my build thread, ill be doing an apple to apple test with the 70mm and then if need be upgrading the turbo to reach 600 wheel.
Old 04-27-2016, 06:34 PM
92SS Wagon's Avatar
I've actually read several of your threads from the past.I'll be sure to keep an eye out I appreciate it
Old 04-27-2016, 09:10 PM
zero2sixT's Avatar
Originally Posted by kbracing96
Yeah, It depends on your goals. If you just want a fun daily around 450-550 hp, then I stick with a smaller S366 or S369. Will spool really well on a 5.3 and be a blast on the street. A S475 is a 800+hp capable turbo and as such, won't spool as fast on a 5.3. It really all depends on what you want out of the truck.
If I was specing you a turbo kit, I'd build a BW S369, JGS 40mm wg and a 50mm bov. Would be a really fun street truck!
Daily fun and couple track times a year
You pretty much have your answer. Other than that learn how to interpret boost curves
04-08-2016 10:05 PM
rondogacing
03-23-2016 10:38 AM
regency
03-20-2016 07:10 PM
TAPyvehc93
03-20-2016 11:08 AM
rondogacing
03-19-2016 09:40 AM
Quick Reply: Sizing a turbo correctly
