Single or Twin???
Old Sep 23, 2005 | 01:01 PM
CAMMIN03''s Avatar
Banned
Default Single or Twin???
I am having to make a decision, and thats whether I want to go a t-70 up front... or 2 smaller turbos at the headers or behind!!!
The cost isnt that much difference!!
Any input is appreciated!!!
Old Sep 23, 2005 | 01:11 PM
Diablo666's Avatar
I would go with the twins after the headers to keep the teperature low
http://www.airpowersystems.com.au/ls1/ls1.htm just an idea....
Old Sep 23, 2005 | 03:47 PM
TxsAg99's Avatar
I had a similar idea that I wanted to try with the stock manifolds, then small twins (GT-32s or T3/T4s), then high flow cats and dumps. I think the twins would be great for street driving, 0-60 times and such.
Old Sep 24, 2005 | 07:29 PM
.T.'s Avatar
.T.
twins
Old Sep 26, 2005 | 06:56 PM
Yellowsierra's Avatar
Twins JK I think your single turbo setup will turn out good. Ill tell you what when I get my truck done and you get your truck done we will line them up and see which setup is faster
Old Sep 26, 2005 | 09:17 PM
CAMMIN03''s Avatar
Banned
hahaha... well unfourtunantly I think your going to win!!!
Old Sep 26, 2005 | 10:46 PM
leftcoast32's Avatar
FormerVendor
I had a 1992 GMC Typhoon that was (single) turbo charged with air2water intercooler. I think you would have less turbo lag with 2 smaller turbos vice 1 large one. The small turbos spool real fast, especially the ball bearing ones. They would not have to work as hard either which would reduce the heat soak. You could run 2 air2air intercoolers with CO2 and small fans for the track.
Turbo setups become real expensive real fast. If you take your time and do it right the first time it wont be as expensive.
I was toying with the idea of using the A/C to chill the intercoolers before I sold the Typhoon. It all boils down to space and your fabrication skills. There are alot of kits out there now.
Old Sep 26, 2005 | 10:55 PM
CAMMIN03''s Avatar
Banned
Well We are going with a t-70 power master turbo, Spearco Intercooler, Aluminum Piping, TIAL 38mm Wastegate, RFL BOV... and all the other stuff!!
Hopefully this will be what im looking for
Old Sep 27, 2005 | 12:22 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Well i think this is the only thing you havent tried. If you dont do this, i think i might set your truck on fire!
Old Sep 27, 2005 | 12:55 AM
CAMMIN03''s Avatar
Banned
Im doing this!!!!
I cant get it done fast enough!!!
AdaMax
May 16, 2016 11:35 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Velocity1
Oct 2, 2015 08:01 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Closer_2001
Sep 24, 2015 09:15 PM
