Should vented catch can be smoking on 6.0 LS?
Old Jun 8, 2016 | 10:56 PM
  #31
LSter's Avatar
Originally Posted by kbracing96
A "pulsing out smoke ring" is a tale tale sign of a cracked/broken ring land. While the pistons isn't tearing it's self to pieces yet, it way down on compression and letting a bunch of compression past the rings and causing the "puff" of the smoke ring. I bet if you run a comp test, one hole will only have about 50psi of comp. I'm gonna go out on a limb and say its gonna be #7... lol
I agree with Kyle, (rings ) but would not
Replace motor if where me I would remove
Bad holes inspect ring and ring lands
And end gap and reassess...!!!
Old Jun 9, 2016 | 07:03 AM
  #32
Atomic's Avatar
I have a gauge for that
Number 7 always runs the hottest and so is usually the one to fail.
If it went in at 40 and came out at 20 pretty good bet that piston/debris hit it, or detonation alone forced it more together. Post a picture of the plug.
Old Jun 9, 2016 | 08:40 AM
  #33
Lane_Hesser's Avatar
Old Jun 9, 2016 | 09:10 AM
  #34
03sierraslt's Avatar
That's a lot of oil, you got a injured hole for sure. I am with the others, I bet your top ring land is shot.
Old Jun 9, 2016 | 10:33 AM
  #35
kbracing96's Avatar
I little note, the threads get oily because when you get even little oil past the rings, it get pushed up the treads by compression before the flame is lit and then it stays there and doesn't get burned during combustion. A normal healthy LS motor shouldn't have any oil on the spark plug threads.
Old Jun 9, 2016 | 10:37 AM
  #36
In that case, 6 of 8 plugs had oil on the threads, lol. They weren't all as bad as #7 but they did have oil on them.
mdwatts11
May 9, 2020 05:28 AM
lxcoupe
Mar 27, 2016 07:26 PM
tim wellington
Mar 22, 2016 11:38 AM
HDhotrod
18
Mar 18, 2016 10:49 PM
07NBSChevy
Mar 16, 2016 05:41 PM
