Turbo Dyno numbers - Ignition/ SCR/ Questions!
Hey guys just got back from the dyno. Tuner says truck is breaking up and he didn't think it was a good idea to turn the whick up past the 9psi gate spring. In his opinion there is an ignition problem of some sort. I am running ungapped Denso IT24 plugs per the tuners recommendation and stock 150k coils and new msd wires. I haven't done a resistance check on the coil packs or done a leak down test yet, although from experience I know that a coil can resistance check fine but till cause a miss. I had that happen on my vette. Anyhow I wanted to start a new thread to sort out the issues before I head back to the dyno. The good news is we loaded a flex fuel Avalanche os and the truck was tuned on 70% ethanol (10 gallons of e85 + a gallon of 91). Truck made a pathetic 456/477 @ 9psi and doesn't feel too fast at all.... Tuner did say that my pcm doesn't handle ethanol content as well as the C6 vettes do and I need to allow 15 or so mins when changing fuel mixtures with the flex fuel tune loaded. Most of the time I plan to run around on pure e85.
Anyways, any idea where to start? I need to log before I go back to the dyno but what parameters should I be looking at given that afr's look fine?
MSD wires are fine
Likely issue is plug gap too wide
Also I would never trust "virtual" alcohol content fueling. I would recommend you install an actual content sensor with appropriate OS.
Numbers aren't bad for a 5.3 and you barely pulled to 5500.
I do have an actual sensor and it's wired to pcm. I don't know what gap is on IT24s but you guys think I'm getting spark blowout? Im tempted to to run a TR6 at .030" like so many guys seem to do with good results.
Originally Posted by GMCtrk
run br7ef @ 0.028.
Any kind of sputtering, hesitation at wot is spark blowout
Remember, all turbo setups usually have hiccups when first starting off.
Ok so as soon as I got back from tuner (4hr+ drive) I decided to do something about the ignition situation. Parts store was closed so no BR7's to be had so I raped my vette for its coil packs, ls7 plug wires, and tr6 plugs that I regapped to .035" and when I started the truck the idle was a lot smoother. I put it in reverse to take it for a test drive and damn near put it through the wall as the throttle response was way crisper. Everything is different now. Truck feels like an animal but I still have the boost cut on the controller set to 9psi, although the Innovate gauge playback shows peak of 11.7psi? Afr's are steady 11.5-11.6:1 so I think I've essentially corrected the ignition issue and the truck was tuned around a miss on one or more cylinders. Which is fine, as afr's seem safe at least at current boost levels. The truck will light up the tires real hard from a 2nd gear roll but I feel there is way more on the table given the ignition issues. Not sure if I should bother swapping BR7's in before retune or not as I've heard so many guys running even 18-20psi on TR6's gapped at .035" or even stock48 who said he didn't even change the gap when he threw his in, which would be .040-.045"
