s484 alternatives
Old Mar 18, 2016 | 02:39 PM
  #31
GMCtrk's Avatar
The 87 j wheel turbine seems like a nice option for the street. Id like to try it sometime
Old Mar 18, 2016 | 04:02 PM
  #32
JordanH's Avatar
Restricted
Originally Posted by AkSSS
My setup has a cast 80/87 with a 50mm jgs gate. My gate is in the cross over also. I was able to run at 4psi when I first started tuning the setup. I was impressed that it would gate that low. And this setup should spool well on the street. I still haven't gotten it turned up over 7psi before it snowed.
Just my experience with my setup so far.
I haven't had any problems holding 8psi with my Tial 44 gate in the crossover on current setup... And that's WOT.... And it prolly would've worked on my new setup too, but I had to purchase a new gate anyways so I went ahead with the 60! I wanna be able to hold a lower boost level for street driving... 8-12psi.. The higher boost level is mainly gonna be for the track!
Old Mar 19, 2016 | 05:39 AM
  #33
AkSSS's Avatar
My truck is mainly for the street. I have taken a lot of heat for not going with the 96 turbine. I am curious to see how it all responds. I think I am going to need a little more converter to help it spool. But again, going for more street, that's why I left the comp. at 9.65.
To the op- I don't have near the experience as most in this thread. But i think a s480 would get you everything you are after.
Old Mar 19, 2016 | 09:28 AM
  #34
Lil brother PI's Avatar
Bullseye is bad *** turbos check em out sevral trucks down here putting down great numbers
Old Mar 19, 2016 | 11:27 PM
  #35
Jake75's Avatar
After being at tx2k the past 3 days I'm itching to finish this truck...any recommendations on who to use for transmission work in houston anyone?
TimDave217
Jun 1, 2016 06:01 PM
Strongsperformance
Apr 17, 2016 09:04 AM
ClintBeastwood
Mar 21, 2016 11:52 PM
dkutej
Mar 20, 2016 11:02 AM
GMCtrk
Mar 19, 2016 06:49 PM
