reduced engine power
Old Jul 28, 2009 | 06:46 PM
trenz68's Avatar
Default reduced engine power
I installed a 90mm elbow on my radix, with a trail blazer 90mm tb, and a x link. When I drive normal is works but when I stomp on it...the code pops up and goes down to 20mph...any help
Old Jul 28, 2009 | 07:41 PM
terravast4's Avatar
Is it from a ss or just a regular trail blazer?
Old Jul 28, 2009 | 07:45 PM
trenz68's Avatar
Trail blazer ss 6.0
Old Jul 28, 2009 | 07:49 PM
ssavalanche's Avatar
Got tuning capability?? If so you need to increase your 1514 table. It will solve your issue!
Old Jul 28, 2009 | 08:27 PM
trenz68's Avatar
Ya I was tryin to run it to see where it was at so my tuner can mess with it...should I raise the tune first instead of driving and tuning?
Old Jul 28, 2009 | 08:35 PM
KySilverado's Avatar
yes if the code being thrown is specifically p1514 you need to raise that table. I had to twice. 10% at a time if I remember correctly. In HPT its under engine diag/general/calc airflow p1514 error.
Old Jul 29, 2009 | 12:24 PM
trenz68's Avatar
No that code is not coming up, it a 2101 code..funny thing is that I put my friends ls2 off a gto and it would not stall when I stomp the gas and the code does not show...
Old Jul 29, 2009 | 12:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
Last I checked you did not need the X harness for the TBSS.
Old Jul 29, 2009 | 01:02 PM
Flaco's Avatar
8 Second Club
P2101 - Throttle actuator control module range
DTC P2101
Circuit Description
The commanded throttle position is compared to the actual throttle position based on accelerator pedal position (APP) and possibly other limiting factors. Both values should be within a calibrated range of each other. The engine control module (ECM) continuously monitors the commanded and actual throttle positions. This DTC sets if the values are greater than the calibrated range.
Old Jul 29, 2009 | 01:26 PM
BlownChevy's Avatar
blownerator
25 Year Member
FUG ME....just read the thread again......sounds like it may be calibration related.
