reduced engine power
Old Jul 29, 2009 | 01:33 PM
Midnightrider's Avatar
ok this is common when the tb is messed with check all you wires make sure they are properly connected. If this doenst fix it check your ground wires RDE is most common with bad or lose grounds
Old Jul 29, 2009 | 04:52 PM
trenz68's Avatar
ill doubled checked all the wires are connected. I've tried two working trailblazer tb and the code shows..I tried a l2s tb and the code does not show? Blown chevy let me try to run it without the xlink with the trailblazer tb
Old Jul 29, 2009 | 08:35 PM
DrX's Avatar
DrX
Is the X-Link set up for the TBSS style 90mm?
Old Jul 29, 2009 | 11:00 PM
trenz68's Avatar
That's the problem..the xlink is set up for ls2 tb..because it works fine with a ls2 tb
Old Jul 30, 2009 | 08:39 AM
DrX's Avatar
DrX
Do you have the 2.1 version which has a pink wire loop inside each wire loom?
Old Jul 30, 2009 | 10:28 AM
trenz68's Avatar
no pink wire loop..im guessing i have an older version
Old Jul 30, 2009 | 10:36 AM
KySilverado's Avatar
Get a new x-link or an ls2 TB. ??
Old Jul 30, 2009 | 02:24 PM
DrX's Avatar
DrX
If it is a plug n play model with no pink wires, it will only work with the car style 90mm.
If it is the 1.0 version with the long pink wire that you connect to a 5V reference, you can get it to work with the TBSS TB by connecting a jumper wire between the 2 grey wires on either end of the unit.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
steves86ta
Jul 28, 2015 10:21 AM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
