Radix and N20
Old Apr 20, 2007 | 09:36 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Oh man Well it sounds like that but I dont have a plate. It seems to get loud then not so loud. I checked th pulleys but dont see or feel anything unusual. Got up in the bay but could not pinpoint the source.
Old Apr 20, 2007 | 09:39 PM
trever1t's Avatar
Originally Posted by DozerDan
mine whistles my WOT switch on my last truck stuck...it made a mess...blew gas an nitrous out my air filter...it looked like a giant popsickle
Kind of glad I wasn't there when it happened Do you have a tb plate setup?
Mine is tapped into the intake tube at the airbox end.
Old Apr 20, 2007 | 10:07 PM
Phantom's Avatar
11 Second Club
yeah i have the NOS LS1 plate system on this truck. I had an NX shark nozzle on my last one with the hole tapped about 1" before the bend on my volant intake tube.
Old Apr 20, 2007 | 10:14 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Strange that the 35 shot was worth 35 and not more. This was on top of 10psi?
Time to go with a 50shot. It might be just enough to see the cooling effects on the boost.
Did your IAT's drop when you sprayed?
Old Apr 20, 2007 | 10:21 PM
Phantom's Avatar
11 Second Club
might be just enough to see what the limit of a stock L33 is as well
nightrunner's Avatar
Mr. Obvious
Old Apr 20, 2007 | 10:23 PM
1SlowHoe's Avatar
This is info people need
For example, mine was good to 10psi@ 13.1 AFR
Old Apr 20, 2007 | 10:27 PM
trever1t's Avatar
My peak boost previously was 9.6lbs but today without n2o peak boost was about a lb less. Rick said I made a little less than 9lbs today.
I really need logging software
Old Apr 20, 2007 | 11:18 PM
Last Call's Avatar
TOTM: January 2007
I am sure rick will get the bugs worked out... Congrats on the new numbers!!!
Old Apr 21, 2007 | 09:38 AM
trever1t's Avatar
Thanks J.
A/F is spot on high 11's . Cant wait to get this all buttoned up and to the track to see how much the $$ just spent helps.
