Radix Mod.
Old Dec 11, 2008 | 07:36 PM
03tahoe22's Avatar
Default Radix Mod.
I am currently running a 3.4 pulley and Badly in need of an upgrade! What do you think the Horsepower, Torque, 1/4 mile difference will be between a 3.2 pulley or a 3.0 pullley with headers, both will be running around 8psi since I have heard you loose 2psi with headers. Is it worth it to buy the longtubes for the cost ($525 OBX) or will I see the small differnce? I know tunning is going to be needed and dont want to do the pulley have it tuned then add the headers and have to have it retuned.
Old Dec 11, 2008 | 07:41 PM
chevrolade's Avatar
Im in the same situation,im running a 3.90 pulley at 5-6 psi,im going o install a 3.70 for 8lbs as well-they say for every .10 you go down its like 15hp.good luck man
Old Dec 11, 2008 | 07:48 PM
old motorhead's Avatar
What engine size? Which blower? 112,112HH,122?
Old Dec 11, 2008 | 07:53 PM
03tahoe22's Avatar
Mods in Signature.
Old Dec 11, 2008 | 08:05 PM
Mods in Signature.
Dam.....I swear I looked. The 3" pulley with long tubes won't over boost you. Will need a tune though. A boost cooler would be a nice addition. You'll be around 9psi. No need to do one then the other. I don't know the HP increase, but I do know you'll like it!!
Old Dec 11, 2008 | 11:16 PM
1989k1500's Avatar
You should get quite a gain by adding long tubes and pulleying down.
Old Dec 12, 2008 | 07:31 AM
Doobie's Avatar
My truck mods are similar to your own. I have LT's with my Radix and am currently running a 3.3" pulley and seeing 7.5~8 psi at wot.. LT's will help with efficiency and a good tune will be a must to realize the full gains.
Oh yeah...it will be a lot louder too! Adding high flow cats will help with the noise a lot too.
DO IT!
Old Dec 12, 2008 | 08:03 AM
thunder550's Avatar
High on diesel fumes
5.3 with a 3.0" pulley and long tubes would be sweet! You'll probably be around 10-11 psi though, not 8.
Old Dec 12, 2008 | 09:12 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yes. True. I make between 172-182kPa with the 3" pulley, depending on weather, a solid 175kPa average. (175Kpa=10.7lbs at sea level)
Old Dec 12, 2008 | 09:46 AM
03tahoe22's Avatar
How much less performance will i get by just going to a 3.2 pulley and not putting on the headers?
bagged7104SS
Sep 24, 2015 08:42 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
tbyrne
Oct 27, 2003 02:46 PM
SSHOTRODSCOM
Aug 5, 2002 01:28 PM
