90mm worth it
Old Dec 10, 2008 | 12:33 PM
BlownHD's Avatar
Default 90mm worth it
Ok so mods are in sig, Would installing a 90mm TB on my truck right now be worth it. I already have the j-tube so I only need the DRx harness and the TB which would probably only run about $400. Will I see many gains or will the stock exhaust manifolds be my restriction. I do plan on installing LTs at some point but money is tight to do the exaust right now.
Old Dec 10, 2008 | 12:45 PM
dhpro's Avatar
Ya...it"ll be worth it...IMO u cud prob do without the DrX gizmo if u get one of the newer TB's (not sure tho). I dont know how much u really leave on the table with it in actual fact anyway. That said ull def see a diff with the 90mm.
Old Dec 10, 2008 | 02:16 PM
BlownHD's Avatar
so your saying that the 87mm TB from a NNBS might work without the drx harness?? if so that would be nice.
Old Dec 10, 2008 | 04:17 PM
old motorhead's Avatar
I don't think you'd see much improvement the way you're set up right now. Spend the money on the exhaust. Then maybe a boost cooler. Then maybe a smaller snout pulley. Then maybe a bigger blower. And then...........
Old Dec 12, 2008 | 07:14 PM
99ta's Avatar
Can anybody confirm this, very interesting.
Old Dec 12, 2008 | 08:34 PM
DrX's Avatar
DrX
The truck and car style 90/87mm TBs both operate in the same manner. Neither one will work unless you correct the TPS signals. Most people are already using the truck style TB on their conversions.
natejk
Nov 15, 2016 08:05 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
