Radix to Livernois Install in progress!
Old May 13, 2007 | 12:47 PM
  #121
thunderwagen's Avatar
Originally Posted by Bill Reid
...maybe valve float? 10-11lbs of boost... I would suspect that if you haven't changed the springs...
Bill
No I havent changed the springs, and that is one of the things I am suspecting.
Old May 13, 2007 | 12:50 PM
  #122
Originally Posted by WJ MARK
Yeah I put my plugs in after installing eveything. Its really not any tighter than before the Turbo.
That must be nice! A plug change for me is about a four to five hour project. I have to pull the oil lines,Turbo, cross over, down pipe,oil dip stick tube, and pass header to get to the plugs. What a PITA. But on the other side of it I am getting really good at getting all that crap on and off.
Old May 13, 2007 | 02:24 PM
  #123
1SlowHoe's Avatar
Destroyer of Transmissions
I would almost guarantee that's at least part of the problem. Sounds like for you a spring change is easier than a plug change. A good set of springs isn't much more than a good set of plugs. I'd do the springs before I tore into the hot parts.
Old May 13, 2007 | 11:10 PM
  #124
Thats the plan right now! Gonna get a set tomorrow.
Old May 14, 2007 | 06:02 AM
  #125
BigTex's Avatar
Mike - what springs do you have in there right now? Comp 918s?
Old May 14, 2007 | 12:50 PM
  #126
Stock...........what would you guys suggest?
Old May 14, 2007 | 01:02 PM
  #127
tiffo60's Avatar
i suggest you put the heads on you have sitting in your floor
Old May 14, 2007 | 01:05 PM
  #128
Im saving those for a special occasion! But the springs in those would work great!
Old May 14, 2007 | 01:33 PM
  #129
kbracing96's Avatar
You can get yellow LS6 springs from SDPC for like $60. There good to .570 and I haven't had any problems with them.
Old May 14, 2007 | 01:41 PM
  #130
Bill Reid's Avatar
I am going to run the Comp 918's... as I may research a cam that will better suit my turbo. 918's will give me a little more room to play with. I concur with kb though... the Z06 springs are also good... and cheaper than the 918's.
Bill
