Radix idler pulleys out of alignment
Old Oct 13, 2009 | 10:44 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by turboescalade
K, well did u take the spacer and the washer behind the spacer off the idler before you bolted it onto the bracket? If u didn't, that's the problem, if you did, make sure that the pulley is actually flush against the bracket. I had a problem not getting the pulley to snug up over the outer lip. I had to file that lip down a bit and then the pulley finally tightened till it was flush. Hope this helps u out cuz that's the same bracket I was having issues with
+1, I remember having to do this also.
Old Oct 13, 2009 | 03:08 PM
CashDudeHomie's Avatar
Idler pulley by the alternator was warped! I noticed when checking for the washer which I must have already removed. Thanks so much for the help guys.
Old Oct 13, 2009 | 08:20 PM
I put a new idler, but it still squeaks. I let it run and then shut it off and checked belt alignment. On both idlers, on the supercharger side, the belt is on the very edge of the pulley. On the tensioner side and alternator side, the belt is properly on the idlers. So the problem HAS to be the supercharger pulley. It is an aftermarket smaller pulley, so maybe that it why it is off by a mm or 2.
I'll have to find a spacer, make one, or order a new pulley (2.75 maybe?) .
Vortec350ss
Jan 12, 2016 10:36 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
