Radix 5.3....DTC
Old Sep 2, 2007 | 08:28 PM
02Tahoe's Avatar
Default Radix 5.3....DTC
Hello..hopefully some one can help me out. DTC #1221 keeps coming up. SES light on, reduced engine power also lights up.This happens just driving around town.When I clear the fault with my interceptor scan gauge, Im able to continue driving. It started about 10 months after the radix and headers were installed..I even removed the radix ( superchips tune) to stock...then re-installed it. I replaced the TPS and throttle body....truck is a 02 Tahoe ..Im not sure the radix has anything to do with this problem. any Ideas? Thanks
Old Sep 2, 2007 | 08:32 PM
thunder550's Avatar
High on diesel fumes
P1221 = Throttle Position Sensor 1-2 Correlation
I can't be any more help than that, but that's what the code is. Might check the wiring to the throttle position sensor.
Old Sep 2, 2007 | 08:46 PM
BlownChevy's Avatar
blownerator
25 Year Member
sounds to me like the wire extensions to the TB are either crossed or not crimped with quality connectors.
Old Sep 4, 2007 | 07:56 PM
02Tahoe's Avatar
Thanks ......Ill check those wire connections
Old Sep 4, 2007 | 08:39 PM
KySilverado's Avatar
Yep, happens to me sometimes when I clean my engine. I have a 90mm TB and a pigtail for it that isn't so watertight. I have to pull it apart and blow the water out... so could be a connection problem.
bagged7104SS
Sep 24, 2015 08:42 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
Dave95Formula
99
Sep 14, 2004 06:11 PM
Fun Guy
80
Dec 13, 2003 08:38 PM
