radix ?
Old Nov 30, 2006 | 06:04 AM
05crew's Avatar
Default radix ?
some one told me that a radix did not make good H.P after 10+ psi. is this true i would like to run 13+ on a forged 6.0 me and GMGen3 are putting together! he says procharger and his bro has one. but i would like to around 600 rwhp. can i get that out of a radix.
the motor is a 9.1, with dish pistions. thanks for the help!
Old Nov 30, 2006 | 07:23 AM
Dub Silverado's Avatar
Magnacharger now has a larger displacement blower that would easily be capable of those numbers. I think the smaller radix is good for about 10psi on most motors before it become too ineficient.
Old Nov 30, 2006 | 07:50 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Contact BlownChevy on this forum, he can give you the info you need.
Old Nov 30, 2006 | 08:32 AM
thunder550's Avatar
High on diesel fumes
The MP112 seems to be limited to somewhere between 500-550 rwhp depending on the setup. Then it spins so fast that it just becomes a heat pump. You'd MIGHT see 10 psi on a 6.0 if you could kill belt slip completely, maybe with a custom 8 rib pulley setup.
I think that 12-13 psi would be possible on a smaller cube motor.
Old Nov 30, 2006 | 03:57 PM
8ALTNG's Avatar
I made 11lbs with my 4.8 liter/radix combo. That was with a 3.25" pulley. It could have made more but the CR was too high and I would have has to drop down to a 2.75" pully....but i can be done.
Old Nov 30, 2006 | 04:02 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Procharger would be better IMO, plus I havent seen anyone with the 122 yet in a truck and the results I have seen so far on the few 122s out there arent that stellar.
Old Nov 30, 2006 | 04:06 PM
8ALTNG's Avatar
Truthfully...........I would go turbo. Caint beat the power and performance. Plus I know of a kit that is for sale for CHEAP!!!!!!!!
Old Nov 30, 2006 | 04:07 PM
1slow01Z71's Avatar
I would go turbo too, in fact I did Was just picking one of the two choices he posted about.
Old Nov 30, 2006 | 04:13 PM
05crew's Avatar
with 10psi on the 6.0 and say 100 to 125 shot of N02 would it make the 600 to 650 mark that i am looking for. the motor just got back from the shop and all i need is tha blower and pick some heads and a abnoxaious, stupid sounding cam and thanks for all the help i just have very little time and need some fast help!
Old Nov 30, 2006 | 04:19 PM
05crew's Avatar
the turbo is not out! it is out of my 4k price rang! and i was told it req.s a lot of computer time and i dont want all that! the motor and heads has rack up to much$$$$$ so far. sot 4k is all i want to spend. thanks 1slow01z71 and 8altng
