radix ?
I made 9psi on a 2.75" pulley on my 6L with a cam that was not good for FI. After adding the LT's and true duals I am down to 7psi. PSI is not a good measure of power anyway. I made the exact same power when I went from 9psi to 7psi with the long tubes. So a truck with stock exhaust and 9 pounds of boost isn't going to automatically make more power than the same truck at 7 pounds of boost and a free flowing exhaust. It's the overall setup that matters.
The Radix will make 10+psi on a 6L but I don't think it would be making much more power than at 8psi with more timing. Get a bigger compressor (MP122HH) or the Procharger, or a turbo. The turbo wouldn't require any more tuning than the Radix.
With the proper cam(its not going to be obnoxious like you are wanting a good FI cam general has little or no overlap the sound you want is caused by cams with alot of overlap) and the STS kit 8altng has you could make your mark on just boost no need for nitrous.
Originally Posted by 05crew
some one told me that a radix did not make good H.P after 10+ psi. is this true i would like to run 13+ on a forged 6.0 me and GMGen3 are putting together! he says procharger and his bro has one. but i would like to around 600 rwhp. can i get that out of a radix.
the motor is a 9.1, with dish pistions. thanks for the help!
nobody has a sts around were im from, are there set backs with the kit that i dont know about. one of my good friend has a procharger D1sc on a stock 5.3 and made 415rwhp
i would like to do somethink diff. and i would like to know of a cam that has a very nocidable lope but is still a good blower cam. thanks for all the help
https://www.performancetrucks.net/fo...d.php?t=379868
i cant get the SOB to play. im on a lap top in F.L. i will be back at home in N.C by sat. ill here it then! if i like it how much do u want for it. and will it do good with a all N02 set up. will the 6.0 take away from the lope!
thanks
do u have a sound clip of it?
