Quick question for the pros
Old Mar 14, 2006 | 08:02 PM
03lowriderss's Avatar
Default Quick question for the pros
my buddy is doing a d1 sc on a stock c-5 5.7 LS1 he thinks he is going to run about 12lbs or boost will that motor puke out shortly there after? it is a 6 speed if that helps.
Old Mar 15, 2006 | 02:37 AM
F8L Z71's Avatar
Not if the fuel system, cam and tuning is done right but doubtful he will go that high.
My buddy just dyno'd tonight in his 5.7 SS LE Camaro with a blower cam, stock 6.0L heads and a D1 (9psi) and did 548rwhp@5800 where they had to shut down because of fueling issues. So figure he has a chance at about 560-570 at 6300rpm where he is meant to max out. That's not to shabby so I'm not sure how long a stock block would hold up to well over 600rwhp that the 12psi COULD induce lol. Even on C5s which dyno lower than Camaros.
The other thing is PSI is not a good number to go by, its different depending on a lot of stuff. He should be saying how much HP he wants to try and make, not how much PSI.
Old Mar 15, 2006 | 10:16 AM
Wilde Racing's Avatar
How do I change this text
I think we need more info on his set-up.
Old Mar 15, 2006 | 12:44 PM
COMPLETLY STOCK 5.7 LS1, he got a good deal on the D1 used, so he bought it there is no cam no nothing stock manifolds. he will get it tuned,oh yeah and he has a fram air hog drop in, he said that these motors can handle the boost.
Old Mar 15, 2006 | 01:01 PM
It can if the fuel system can keep up, and the tune is good. I'm running 12psi of boost in my 6.0l and it is all stock but the valve springs.
12 to 15 psi would be the limit imo, now if better pistons where used......
Three6GMC
Aug 28, 2015 07:56 AM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
