Quick oil feed line question
Old Oct 4, 2008 | 01:18 PM
v8bug's Avatar
Default Quick oil feed line question
I admit I dont know alot about the genIII oil system so I just want to make sure this will work before I continue.
I plan on drilling and tapping the small unused adapter thing (or whatever you call it) with a 1/8" npt thread and using a ~3/16 feed line to the turbo. I remember hearing somewhere others where using this to feed their turbos.
By the way, what was this supposed to do from the factory?
pics of what I am talking about....
Old Oct 4, 2008 | 01:24 PM
Bill Reid's Avatar
Yes, you can tap that out... be careful... it has a tendancy to crack. That is where I get my oil. When that part is drilled / tapped at the factory it is for vehicles with engine oil temp sensing option.
Old Oct 4, 2008 | 02:07 PM
charcold-bowtie's Avatar
yeah tap the little bolted on thing, thats were mine is. I think it was for oil coolers.
Old Oct 4, 2008 | 05:37 PM
Mort's Avatar
That is where the adapter for the oil cooler on my truck is mounted. I just drilled the bottom of the adapter for the fitting to supply oil to my turbo per STS instructions.
Old Oct 4, 2008 | 08:07 PM
TrickTurbo's Avatar
Truck Sponsor
Yep thats the place where to get oil from. The purpose of that part is to get pressured oil back to the engine. Trucks that have oil coolers would have a block with tubes running up to the front for the oil cooler.
Make sure you clean it good after tapping.
Old Oct 5, 2008 | 07:37 AM
v8bug's Avatar
thanks for the quick responses guys! I'll get working on it today
Old Oct 5, 2008 | 09:16 AM
ONLYA4.8L's Avatar
If thats where u get the oil from... Where does the return line go?
Old Oct 5, 2008 | 11:03 AM
kbracing96's Avatar
Usually you dill and tap the side of the oil pan for the return.
Old Oct 5, 2008 | 02:24 PM
this is shot from the passenger fenderwell. Make sure its down hill.
chopperloco
Jul 10, 2016 10:45 PM
USMCvet0311
Aug 1, 2015 07:45 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mzay
Jul 6, 2015 11:03 PM
