Questions around procharger rebuild
Old 03-09-2013, 05:42 PM
Blowndenalixl's Avatar
Default Questions around procharger rebuild
So it has become evident that i should have the p1sc on the escalade rebuilt if I am going to keep the truck. I have talked to procharger and know my options about rebuilding as a p1sc or as a d1sc.
For the month or so that the vehicle will be without its procharger, I would like to be able to move the vehicle around without the aid of a tow truck. I have a two car garage and three vehicles and the escalade is low car on the totem pole.
My question is this: what else would have to be removed/replaced so that I could start it up and creep from the driveway to the street and back?
Extra question for if I decide to go with the d1sc: with the tune I have now (set for 5 lbs and meth by Allen Nelson when he tuned the vehicle for me before it was shipped to Canada), could I nurse it down the highway about 100 miles to a tune shop that has an AWD Dyno for the new tune? Or just too dangerous and better to rent a vehicle trailer?
Thanks gang.
D
Old 03-09-2013, 05:56 PM
AndysC3's Avatar
Just unbolt the bracket, run the stock belt and the stock air box.
Old 03-09-2013, 06:04 PM
Thanks much.
Old 03-10-2013, 08:52 PM
04SilverCrew's Avatar
Just curious... why does the blower need rebuilt? Also, do you have future plans for your rig?...i dont think 5 lbs of boost requires an upgrade to a d1.
Old 03-10-2013, 10:15 PM
It is leaking oil. if i upgrade to a D1 definitely upping the boost.
Old 03-20-2013, 01:24 PM
BlownChevy254's Avatar
What are they wanting to charge for the D1 rebuild?
Old 03-20-2013, 02:19 PM
Baltimore Whore
Mangled03gmc's Avatar
The D1 in it self is going to run better at the same boost level. I will come in alot harder. Make sure you clarify with them about the oil issue. I was told numerous times rite from them that even brand new ones can seep oil from the seal and it is not a warrantied issue..
Cost on a P1 to D1 is usually about 1100-1400
D1SCSS
01-25-2016 10:14 PM
chevy6.0fan
08-20-2015 07:10 PM
blownss27
08-14-2015 03:31 PM
USMCvet0311
08-01-2015 07:45 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: Questions around procharger rebuild
