project "cadzilla"
Old Apr 16, 2010 | 07:16 PM
turboescalade's Avatar
Default project "cadzilla"
Thats what the tuners at the shop are calling my cadillac now. haha. So here's the problem. They have been trying to work out my traction control and were makin some full throttle passes. Apparently they shredded my rear cog drive belt. And they have been moving the shift points down to 5700 and it still goes up to 6 grand. They think its the TC. I think that it cant shift fast enough when the boost comes on.
SO. First one is Has anyone shredded their cog? and where could I get one?
Second. Should I be worried about my converter? or is this just a beast and thats the soonest it shifts?
Old Apr 16, 2010 | 08:21 PM
phasemaster1's Avatar
Breaking the tires loose?
Old Apr 16, 2010 | 08:22 PM
Old Apr 16, 2010 | 08:24 PM
acethedragon's Avatar
wat kind of work has been done to the transmission? is it still a 4l65e in there? the torque converter shouldnt affect shifting like that. you should have a higher stall converter with that cam anyway but all that will do is take some load off the motor and give you some rpms on the back side of the shift - wont fall back as far. if the tranny is stock, your overpowering the shifts. it is starting to shift where you want it to but slips a few hundred rpms before it can complete it. hope this gives you something to think about
Old Apr 16, 2010 | 08:48 PM
yea it breaks the tires loose
sorry, I have a built 4L80 in it with a TCS 3000 stall.
Old Apr 17, 2010 | 10:10 AM
thats interesting. i dont have much experience with the 4l80e but i know its all clutch to clutch shifting. none of the old bands and servos like the 4l60e. good luck with it. sounds like a beast
Old Apr 17, 2010 | 11:26 AM
bansheerider44's Avatar
thats what my first 80e did right before it completely **** the bed. Not sure what gave in it but my new built one shifts perfectly at what rpm its commanded to.
Old Apr 17, 2010 | 04:09 PM
DrX's Avatar
DrX
Another vote for the trans is slipping.
Old Apr 17, 2010 | 11:57 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Check to see if the pcm is commanding the trans to shift at the requested rpm.
If it is, then the trans is slipping.
If not, then try lowering the shift points to 5500rpms, and use the normal and wot shift speeds to shift the trans by mph instead.
Old Apr 18, 2010 | 04:18 AM
Blown06's Avatar
8 Second Truck Club
If your blowing the tires off it'll never shift when its supposed to. My experience anyway.
