ProCharger Tune
Old Jun 25, 2010 | 07:23 PM
wentbig's Avatar
Smile ProCharger Tune
02 2500HD 6L P1@11psi Meth- Dual Magnaflows-every other thing stock.
Just got off the dyno my timing was at 0* at full boost the tuner took it to
10* and I picked up 100 whp. now 425whp
Now it is smog time in Ca. Took it to the shop Passed with flying colors in
pm,nox,co my truck is 66% cleaner then the average in Ca.
Shows what a good tune will do.
Old Jun 25, 2010 | 08:31 PM
Blown06's Avatar
8 Second Truck Club
Your timing numbers are jacked! Why was it ever at 0*?....and then why only bump to 10*?
Old Jun 25, 2010 | 08:44 PM
03sierraslt's Avatar
Is it intercooled?
Old Jun 25, 2010 | 09:37 PM
wentbig's Avatar
The first tune was by the installer. I think he was trying to protect the motor because I some times pull a trailer. This last dyno tune was done with HP Tuners and I asked why not 15* or more the tuner said he was avoiding knock.
We tuned with Meth and af# all look good. The only way I would run more timing is with LT Headers it is just too pluged up.
It can't be too "jacked" The truck weighs 7100 lbs. I run a 3200 stall.
At the track I have to run in 4X4 to hook up I get a 1.98 60' and 14.2 ET
Try that with a 7100# brick all stock with a compressor.
Old Jun 25, 2010 | 10:37 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
what tuner did you end up using. No links please, just the name?
Old Jun 25, 2010 | 10:49 PM
wentbig's Avatar
SVS R&D in Sacramento Ca. $500. for the dyno tune and I had him wire my Efans. The Nelson harness came incomplete no conectors for the fan and short wires, took 4 hours labor just for the fan wiring and mounting relays.
Old Jun 26, 2010 | 02:06 PM
sureshot's Avatar
You shouldn't be seeing knock at 10*, or 15* for that matter, especially with meth. I'm currently running 14#'s of boost and 20.5* timing and have no KR at all, and have never seen KR on any of my logs.
Old Jun 26, 2010 | 07:46 PM
Blown06's Avatar
8 Second Truck Club
Word!
Old Jun 26, 2010 | 09:28 PM
wentbig's Avatar
Question
I told the tuner I wanted numbers. He said I need LT Headers to open-up the motor and run more timing. Does that sound right to you?
Old Jun 26, 2010 | 11:00 PM
sureshot's Avatar
No, LT headers will make a difference. They won't make a big enough of a difference on that scale. Who does your tuning?
chopperloco
Jul 10, 2016 10:45 PM
D1SCSS
Jan 25, 2016 10:14 PM
mzoomora
Jan 3, 2016 07:06 AM
Ls3silverado
Jul 31, 2015 04:22 PM
fcompean
Jul 15, 2015 09:55 PM
